![]() | Home > Technical (L322) > Engine System Fault |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
"Engine System Fault" warning appears every now and then just after starting car - runs fine so I just ignore it. Is that wise? |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Got any diagnostics to pull the fault codes? .... Also maybe low battery related - try checking your voltage. |
Yep got IIDTool but it doesn't seem to record fault, battery is newish. Geoff |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
I couldn't have put it better myself. |
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
I've had this as well on and off in the last few weeks, daft question but how do I know if it is the EGR thats about to go?
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
simply by doing computer diagnostics
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
I have the same issue. now and again I get the " engine system fault" warning. If I turn the engine off and restart it is OK until the next day. Does anyone know what this could be? Terry. |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
Could be the charge air pipes ruptured |
I would check the EGR, clean it as they have a tendency to gunk up over time and cause issues.
Are they easy to clean? |
There are some posts on EGR cleaning on here. I haven't done it since I have had petrols only |
I got it connected to an obd2 scanner and the following was highlighted. Code P132E turbo/supercharger boost control B performance intermittent. Looks like it could be the turbo actuator sticking. |
Does anyone know if the turbo actuators can be changed without taking the engine out? Or maybe even lubricate the actuators at the roadside?
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1469 ![]() ![]() |
It may be worth buying a short term access to topix to get at the workshop manual and the full code lists.
