Home > Technical (L322) > Engine System Fault
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Thanks Fisha. I believe that the full code is P132E-22 (6Cool which the IID tool highlighted, does anyone have access to topix??? Terry 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #402537 30th Aug 2016 10:28am
kbald
There isnt too much info on that fault from a search I've just done. Looks like it could be related to the actuator arm and the E might relate to which one. I'm sure you have seen that you can free them off but it's tricky to see them so could be tough to do without a ramp or getting the car high up.
Have you tried emailing gap support to see if they can help at all with the code to and if they have anymore info on it? Or you could call up a local Indy if you have a good one and ask them if they have any suggestions.
Post #402545 30th Aug 2016 10:50am
1959terry
Thanks for the advise kbald, i will email Gap. Terry 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
Post #402609 30th Aug 2016 4:16pm
