![]() | Home > Group Buys > flip keys [New Order Oct 2014] |
dba11 Member Since: 14 Oct 2013 Location: Bury St Edmunds Posts: 21 ![]() ![]() |
Cliffy, no, they have wiped there hands of it, as i supplied it. |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
Even though they have miss cut it? that is |
Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236 ![]() ![]() ![]() |
Sounds like it was done on purpose 1994 softail full stars n stripes custom harley davidson |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Snap, I tried this chap and he knackered the blade today so went to my mate near me who was away at the time and hes seen it and said he's cut it too wide and needs blank |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
that sounds a good deal |
anyone had any luck in surrey, Southwark area's?? trying to get my key cut |
a trip across the bridge me thinks clify a day out at southend |
sounds like i might have to, ill drop in to see the guys at the Boat shop in Rainham maybe |
dont know that one upminster marine i know that one 1994 softail full stars n stripes custom harley davidson |
A bit fed up now, had another key cut looks spot on opens door as does the other key i had cut in the drivers door lock but no joy in the car ignition barrel but when i used the old key the solenoid is clicking around the when i hold the key flat above the ignition barrel slot as it should but not on the new flip key, the flip will open doors and lock all so it must be synced right? but if i hold it over the ignition barrel slot in car like the other one theres no clicking so you cant turn to start, anyone have an idea whats the problem possibly?? |
Hi Scottyav,
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 ![]() ![]() ![]() |
Hi Scottyav You definitly have to move the transponder from the old key into the new one but before you do that check if the new key can turn in the ignition to be safe place you're old key next to the ignition lock so it activates the solenoid what is crustal to the key cut is the lengt of the cut if this is not exactly it will not turn the ignition because that lock is a lot more accurat than the door lock.
if i thought this would be hassle id have not bothered tbh,if i put the fob close its hit or miss if i can turn the key, not sure if both blanks are cut spot on by looking tbh but looks like im going to sell the fob had enough messing about now and throwing cash down the pan. _____________________________________________________
I wish someone had told me in the original key theres a small piece of carbon looking block its that what has to be swapped to the new key inside and hey presto its starting perfect |
