![]() | Home > Group Buys > flip keys [New Order Oct 2014] |
Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236 ![]() ![]() ![]() |
PLEASE READ from daveo's post i guess you only have to ask |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
Steve I don't know if you have his phone number but that is the way forward
Daveo
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Confirmed one of the bmw key blanks work perfectly |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Is it possible to take the blade from the original key and get it to fit in to the new style flip key in case the key cutter f....s up the new blade when he cuts it? There is a difference between knowing your sh!t and knowing you're sh!t
Any recommendations as too where I can get the new keys cut (all sync and locking unlocking ok). If it makes it easier I am happy to buy a couple of new blanks from whoever cuts it, either to use in the flip keys if they will easily fit or just to protect their income provided that they do a decent job and cut the blade properly so it works.
Have sent a text rej
flipflop Member Since: 28 Oct 2011 Location: neath Posts: 5 ![]() ![]() ![]() |
At last I've found a key cutter who is more than willing to cut my key, 5mins and £9 later a perfectly cut key works first and every time |
RangeK1D Member Since: 21 May 2013 Location: Calgary, Alberta Posts: 166 ![]() ![]() ![]() |
For making the 2010 key work, is this the correct procedure?
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi, get the key blade cut last, if there is a problem with the key they will not take it back if the blade is cut.. V8 facelift Range Rover Autobiography 22" wheels.
Jmelvinbath Member Since: 12 May 2014 Location: Wimbledon Posts: 16 ![]() ![]() ![]() |
Hi
The new keys work great you need to talk to Davo
hi all, new order going on over the weekend
