Home > Maintenance & Mods (L322) > Jump leads |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
I'd have said 25mm dia leads would do the trick but if you want belt & braces then Halfrauds do a 35mm set that they rate for diesels up to 4ltr. |
29th Jul 2013 11:03pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1762 |
http://www.halfords.com/webapp/wcs/stores/...yId_255204
30th Jul 2013 5:45am |
Simple1 Member Since: 01 Jun 2013 Location: Somerset Posts: 112 |
Need to be extremely careful with LR and jump leads. They can cause spikes that damage ecu's and other components when connecting them. You should really use an anti spike controller or a jump pack with built in anti spike to prevent damage. TDV8 Vogue SE 2009.
30th Jul 2013 6:27am |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
I think thats 25 sq mm, not 25mm diameter... Graham
30th Jul 2013 11:26am |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
Thank you everyone for your advice. The jump leads are for a forthcoming European trip and space will be at a premium so I will have no room for a jump pack. I've no idea what an anti spike controller is. Is it something you can attach to your jump leads?
30th Jul 2013 6:20pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Hi Chris -
30th Jul 2013 7:22pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
i have just got a pair of heavy duty cables from ECP and have jumped to and from the car on several occasions without a problem.
30th Jul 2013 9:20pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Feck have to go out and read the manual now out of curiosity Present :2008 TDV8 HSE
30th Jul 2013 9:29pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7937 |
I have several sets of these (in different vehicles) and rate them
30th Jul 2013 9:39pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16292 |
I was just going to suggest Anderson connectors Will limit poor connections by 50% and save you a tiny bit of space too |
30th Jul 2013 10:21pm |
any ideas as to what sized anderson connectors would do the job? There is nothing that can't be fixed with a hammer😜😜
30th Jul 2013 10:51pm |
I use 175A and they've been fine - seems to be what most people use - I trawled a few Landrover & other sites.
31st Jul 2013 5:30pm |
Wired Anderson Connectors? I'll have to research that on Google. |
31st Jul 2013 5:53pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Question
1st Aug 2013 12:07am |
