Home > Maintenance & Mods (L322) > Jump leads
J90
France 2006 Range Rover Vogue Td6 Java Black
Jump leads
Would someone please recommend a set of jump leads for me please; i.e amp rating/diameter of cables etc.
I need a pair for my TD6 (110amp battery)
Thanks,
Chris
Post #201442 29th Jul 2013 9:51pm
Budgie
I'd have said 25mm dia leads would do the trick but if you want belt & braces then Halfrauds do a 35mm set that they rate for diesels up to 4ltr.
Post #201451 29th Jul 2013 11:03pm
Mikey
http://www.halfords.com/webapp/wcs/stores/...yId_255204
I bought these. When it comes to jump leads, bigger is better. The starter motor can draw a huge amount of current, and the cheaper (thinner) ones do get very hot, and may not allow enough power through
Post #201455 30th Jul 2013 5:45am
Simple1
United Kingdom 2009 Range Rover Vogue SE TDV8 Santorini Black
Need to be extremely careful with LR and jump leads. They can cause spikes that damage ecu's and other components when connecting them. You should really use an anti spike controller or a jump pack with built in anti spike to prevent damage. TDV8 Vogue SE 2009.
TDV8 Sport. Gone. Loved it but it didn't love me!
Other toys in the cupboard.......
Post #201457 30th Jul 2013 6:27am
A1GSS
I think thats 25 sq mm, not 25mm diameter... Very Happy Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #201497 30th Jul 2013 11:26am
J90
Thank you everyone for your advice. The jump leads are for a forthcoming European trip and space will be at a premium so I will have no room for a jump pack. I've no idea what an anti spike controller is. Is it something you can attach to your jump leads?
Chris
Post #201576 30th Jul 2013 6:20pm
TugRR
Hi Chris -
We used to have these at work. They have a box in line in the leads - so the two leads are no longer separate. You may be better off asking a commercial vehicle supplier ? - worth a punt . . .
Paul
Thumbs Up Where do you go after one of these . . . ?
Post #201595 30th Jul 2013 7:22pm
i have just got a pair of heavy duty cables from ECP and have jumped to and from the car on several occasions without a problem.
There is a specific way of connecting the jumper cables to the FFRR see page 269-271 in the manual on the correct order to do things as this is important. There is nothing that can't be fixed with a hammer😜😜
Post #201648 30th Jul 2013 9:20pm
Googsy
Feck have to go out and read the manual now out of curiosity Smile Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #201650 30th Jul 2013 9:29pm
I have several sets of these (in different vehicles) and rate them Thumbs Up
I've permanently wired anderson connectors on our cars and to one end of each cable too Cool
Post #201652 30th Jul 2013 9:39pm
I was just going to suggest Anderson connectors Rolling Eyes Will limit poor connections by 50% and save you a tiny bit of space too Thumbs Up
Post #201659 30th Jul 2013 10:21pm
any ideas as to what sized anderson connectors would do the job? There is nothing that can't be fixed with a hammer😜😜
Post #201666 30th Jul 2013 10:51pm
I use 175A and they've been fine - seems to be what most people use - I trawled a few Landrover & other sites.
They come with a few different cable bores, so make sure you get them big enough Wink
I've soldered mine
Post #201752 31st Jul 2013 5:30pm
J90
Wired Anderson Connectors? I'll have to research that on Google.
Post #201759 31st Jul 2013 5:53pm
RR2008HSE
Question
I'm nervous to jump start a computer/electronic heavy car. And there are few cars with more gizmos than an FFRR. Have people ha,d good luck jumping them?
Post #201826 1st Aug 2013 12:07am
