Home > In Car Electronics (L322) > Digital TV Upgrade
Page 12 of 18 <123 ... 111213 ... 161718>
I'm half way through fitting a non-OEM DAB tuner - results to follow soon! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #61737 27th Apr 2011 7:32pm
is that using the range rovers screen alan? ... - .- -.
Post #61738 27th Apr 2011 7:42pm
Nah, having spoken to Wiggs about this at some length I think that's a long shot, so I've got hold of a Acoustic Solutions DAB-ICS100 which has a separate control box, so I've managed to squeeze that in along with all the other bits in the left hand side of the boot. The only thing that's visible is the control pad.
Pics to follow once it's done and dusted! Got - 2017 SDV8 Autobiography in Loire Blue
Post #61747 27th Apr 2011 8:30pm
you've probably seen this , but if not ,i hope it helps..
http://www.dabonwheels.co.uk/uploaded_files/ICS100.pdf ... - .- -.
Post #61790 28th Apr 2011 9:15am
Thanks for that, I did have it.
I must say these RRs are bloody well put together, I really struggled to find somewhere to put the control box as all the "space" seems to be taken up by padding and sound insulation, so after taking out the glove box and not finding a space big enough, I ended up squeezing it in the boot with all the other A/V bits.
cheers Got - 2017 SDV8 Autobiography in Loire Blue
Post #61796 28th Apr 2011 9:49am
wiggs wrote:
scarey wrote:
any news on the dab modules wiggs..
I have fitted it , enabled it ...but there is nothing in any menus to select it Sad
Still looking into it ...although i suspect thats as far as its going to go . On the new LR's there a setting on the touch screen for DAB
comports wrote:
Hi Wiggs - I think I've asked before but will the Digi TV units work with pre facelift non touch screen units.?
You have ...unfortunatly these are just for the touch screen vehicles Sad
I've just been doing a bit of searching for aerial info and found this wee nugget which might help Wiggs in his search for the DAB menu. This was a topic on Sirius Satellite radio, but maybe it's the same for DAB? :-
If you hit the Aux button more than once and it doesn't flip between AUX, SAT1, and SAT2, then you don't have it. Even if you don't have the service activated you should get the preview channel and the Radio ID, the number you would need to give Sirius to activate it.
I believe all the trucks mid 2006 on have a shark fin, the question is whether they have the sirius antenna in them or not, or if it's just gps or bluetooth. Got - 2017 SDV8 Autobiography in Loire Blue
Post #62001 28th Apr 2011 7:40pm
alan, sirius and dab are different ...sirius uses satellites and dab uses the 200mhz frequency which is transmitted along side the fm radio signals ...afaik the full fats radio uses the very rear screens as antennas , one side for horizontal and the other for vertical polarization... ... - .- -.
Post #62005 28th Apr 2011 7:49pm
I know they're very different Stan, but I just wondered if the method of controlling them from the screen was the same? Got - 2017 SDV8 Autobiography in Loire Blue
Post #62010 28th Apr 2011 7:56pm
gotcha.. Thumbs Up ... - .- -.
Post #62011 28th Apr 2011 7:57pm
Post #62014 28th Apr 2011 8:01pm
wiggs
Will have another play with the dab while at Driffield this weekend ....
Aux button does not switch to any thing other than aux .
Will enable the sirus and see if it gives me any more options
Post #62750 5th May 2011 2:34pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
wiggs, just read through this post and as a new boy am interested in upgrading to digital tv tuner.
could you just in laymans terms let me know what you supply and how much it would cost to get myself digital tv.
thanks alot stu. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #63052 8th May 2011 5:17pm
wiggs
If you already have a tv then it's a straight swap ... 4 connectors ... That's it
So I just supply the new tv module .. Nothing else is needed .£300 + £8 next day delivery
Post #63055 8th May 2011 5:31pm
stu
thanks for the quick reply!! well that sounds pretty straight forward.
unfortunately i can't afford one at the moment, what with just picking the car up yesterday and buying a dog gaurd, load liner and paying for the old girl too.
do you get these regularly?
i will give you a shout sometime when i have some spare cash.
thanks again.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #63057 8th May 2011 5:36pm
wiggs
I normally have them ..although i have been told stocks are getting low .
Just give me a shout when you want one and i will see if i have one / can get one
Post #63141 9th May 2011 3:01pm
