Home > In Car Electronics (L322) > Digital TV Upgrade |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35278 |
is that using the range rovers screen alan? ... - .- -.
27th Apr 2011 7:42pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
Nah, having spoken to Wiggs about this at some length I think that's a long shot, so I've got hold of a Acoustic Solutions DAB-ICS100 which has a separate control box, so I've managed to squeeze that in along with all the other bits in the left hand side of the boot. The only thing that's visible is the control pad.
27th Apr 2011 8:30pm |
you've probably seen this , but if not ,i hope it helps..
28th Apr 2011 9:15am |
Thanks for that, I did have it.
28th Apr 2011 9:49am |
I've just been doing a bit of searching for aerial info and found this wee nugget which might help Wiggs in his search for the DAB menu. This was a topic on Sirius Satellite radio, but maybe it's the same for DAB? :- If you hit the Aux button more than once and it doesn't flip between AUX, SAT1, and SAT2, then you don't have it. Even if you don't have the service activated you should get the preview channel and the Radio ID, the number you would need to give Sirius to activate it. I believe all the trucks mid 2006 on have a shark fin, the question is whether they have the sirius antenna in them or not, or if it's just gps or bluetooth. Got - 2017 SDV8 Autobiography in Loire Blue Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
28th Apr 2011 7:40pm |
alan, sirius and dab are different ...sirius uses satellites and dab uses the 200mhz frequency which is transmitted along side the fm radio signals ...afaik the full fats radio uses the very rear screens as antennas , one side for horizontal and the other for vertical polarization... ... - .- -.
28th Apr 2011 7:49pm |
I know they're very different Stan, but I just wondered if the method of controlling them from the screen was the same? Got - 2017 SDV8 Autobiography in Loire Blue
28th Apr 2011 7:56pm |
gotcha.. ... - .- -.
28th Apr 2011 7:57pm |
28th Apr 2011 8:01pm |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 |
Will have another play with the dab while at Driffield this weekend ....
5th May 2011 2:34pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
wiggs, just read through this post and as a new boy am interested in upgrading to digital tv tuner.
8th May 2011 5:17pm |
If you already have a tv then it's a straight swap ... 4 connectors ... That's it
8th May 2011 5:31pm |
thanks for the quick reply!! well that sounds pretty straight forward.
8th May 2011 5:36pm |
I normally have them ..although i have been told stocks are getting low .
9th May 2011 3:01pm |
