Home > Technical (L322) > RSW Allcoms won't clear Airbag light FIXED
Page 1 of 3 123>
Andy
I've been sat here now for ages clicking on Clear Faults and the airbag light will not go out.
The fault is showing as follows:
Supply voltage less than 9.6v
Internal Error
Anyone point me in the right direction as to where the fault may lie and how to cure it?
Post #180310 29th Mar 2013 6:11pm
Andy
Bump
Post #180404 30th Mar 2013 9:39am
the only thing i can think why its not clearing is that there is a faulty airbag or airbag sensor...it could be a faulty seat occupant sensor like mine had... ... - .- -.
Post #180416 30th Mar 2013 11:13am
Andy
Where's that located?
Post #180420 30th Mar 2013 11:43am
mine was the the passenger seat sensor [under seat cover] the airbag light on the dash would flash as the occupant moved in the seat ...check the connections under the seat first...
is the battery ok? ... - .- -.
Post #180425 30th Mar 2013 11:56am
Andy
Battery is new. Swapped it this morning as it had a 5 yr warranty.
My airbag light is on all the time. It goes out when I start the car, but it comes back on straight away.
Post #180448 30th Mar 2013 3:20pm
i'm stumped with that fault code....i wonder if it refers to the RSW and not the range and thats why you cant clear the error..
on that thought ,it might be worth checking the RSW connection... ... - .- -.
Post #180457 30th Mar 2013 5:10pm
Andy
Spoke to a technician at Land Rover dealers yesterday- he said a common problem on this model year was fractured wiring in the seat.
i would email Storey but I think I upset him last time!
The car failed the Mot yesterday on the airbag light Evil or Very Mad
Post #180566 31st Mar 2013 12:06pm
that was my problem but an intermittent one ..my replacement occupancy sensor was around £100 retail which i didnt pay as mine was still under warranty.. ... - .- -.
Post #180568 31st Mar 2013 12:10pm
Andy
I've just removed the seat and checked the connections. I've belled all of the plugs out and they all bleep, so no problems there.
Plugged the seat back in and re- checked. Allcomms now says no faults , but the airbag light is still on?
Getting a tad desperate now as I have 10 days for a retest and I've used 4 days so far!
Post #181852 8th Apr 2013 5:10pm
ebajema
Black sticky tape or bulb removal ???
Clear all the faults in the Instrument cluster as well. MY 2010 5.0 SC Galway green and sand interior!!
Post #181855 8th Apr 2013 5:25pm
it sounds like you might have to get a proper garage jobby to find the fault code to trace the error..but, before you do that i would do a battery disconnection again , worth a try .. ... - .- -.
Post #181856 8th Apr 2013 5:25pm
Andy
Can't do that- they check to see if it comes on when they turn the key, then to see if it goes out.
Post #181861 8th Apr 2013 5:54pm
daveo
how about the steering wheel air bag, i have spoke to story and he is getting back on with the all comms software Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #181872 8th Apr 2013 7:17pm
Andy
On some forums, the suggestion points to the srs ecu. Will Testbook confirm this as I have a local specialist garage that will run a check FOC.
Post #181873 8th Apr 2013 7:21pm
Page 1 of 3 123>
