Home > Technical (L322) > RSW Allcoms won't clear Airbag light FIXED |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
good news and when you get to fix it yourself adds to the satisfaction Present :2008 TDV8 HSE
12th Apr 2013 11:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35247 |
result.. ... - .- -.
13th Apr 2013 7:00am |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
Well done mate. Phew! |
13th Apr 2013 9:11am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
It was a pig of a job to do, mainly because of having to get the centre console out. A tip if anyone ever has to do it- just take the screws out and lift the rear of the console up and slide a broom stale across the seats to hold it up out of the way. The ecu is under the heater blower which is fixed to a metal frame. That frame then needs to be unbolted to access the ecu. No need to take the front clock panel out as RAVE suggests |
20th Apr 2013 8:49pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
had this on a 2002 i bought, RSW lead would show but not clear fault. bought a secondhand battery disconnect cable as that was the offending text fault along with 'internal error'. still on!
7th May 2013 10:22pm |
Annoyingly, when I returned to retest the car, the tester informed me that a loophole had been discovered in the new legislation.
8th May 2013 7:54am |
