Home > Technical (L322) > RSW Allcoms won't clear Airbag light FIXED |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
^^^^ Thats the way forward. |
8th Apr 2013 7:35pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2937 |
The fault has reappeared on allcomms. I'm also getting another fault since taking out the seat which wasn't there previously/ "drive buckle pretensioner".
9th Apr 2013 10:56am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
just to confirm,
9th Apr 2013 11:02am |
Yes to all.
9th Apr 2013 11:05am |
it would be handy to know which airbag is faulty and/or what is causing the airbag light to come on ...have you considered removing fuses to see which part is faulty [if this is possible that is].. ... - .- -.
9th Apr 2013 11:12am |
Which fuses control the airbags? |
9th Apr 2013 11:15am |
dunno, you'd have to look on rave .. ... - .- -.
9th Apr 2013 11:17am |
Found the fuse (44) its fine and removing /refitting has made no difference. Just left the battery off for 3/4hr too- still no change.
9th Apr 2013 12:19pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
ebajema is right, well worth running through all the ECUs and clearing all faults, due to the daisy chain effect! .
9th Apr 2013 4:31pm |
Tried them all and cleared the faults I came across. Still the same.
9th Apr 2013 4:45pm |
ellismorgan Member Since: 21 Sep 2011 Location: United Kingdom Posts: 9 |
this probably wont help, (re urgent MOT) but I had an airbag fault light on mine (TDV8 2007)
9th Apr 2013 6:56pm |
thats the beauty of owning a fullfat. ... - .- -.
9th Apr 2013 7:00pm |
Been to the garage today and they stuck the Testbook on and its the ECU thats gone.
10th Apr 2013 6:13pm |
Sorted. Bought a used ECU off the bay for £40 and fitted it last night. Airbag light now out! |
12th Apr 2013 11:58pm |
