Home > Technical (L322) > RSW Allcoms won't clear Airbag light FIXED |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I've been sat here now for ages clicking on Clear Faults and the airbag light will not go out.
29th Mar 2013 5:11pm |
Bump |
30th Mar 2013 8:39am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35247 |
the only thing i can think why its not clearing is that there is a faulty airbag or airbag sensor...it could be a faulty seat occupant sensor like mine had... ... - .- -.
30th Mar 2013 10:13am |
Where's that located? |
30th Mar 2013 10:43am |
mine was the the passenger seat sensor [under seat cover] the airbag light on the dash would flash as the occupant moved in the seat ...check the connections under the seat first...
30th Mar 2013 10:56am |
Battery is new. Swapped it this morning as it had a 5 yr warranty.
30th Mar 2013 2:20pm |
i'm stumped with that fault code....i wonder if it refers to the RSW and not the range and thats why you cant clear the error..
30th Mar 2013 4:10pm |
Spoke to a technician at Land Rover dealers yesterday- he said a common problem on this model year was fractured wiring in the seat.
31st Mar 2013 11:06am |
that was my problem but an intermittent one ..my replacement occupancy sensor was around £100 retail which i didnt pay as mine was still under warranty.. ... - .- -.
31st Mar 2013 11:10am |
I've just removed the seat and checked the connections. I've belled all of the plugs out and they all bleep, so no problems there.
8th Apr 2013 4:10pm |
it sounds like you might have to get a proper garage jobby to find the fault code to trace the error..but, before you do that i would do a battery disconnection again , worth a try .. ... - .- -.
8th Apr 2013 4:25pm |
Can't do that- they check to see if it comes on when they turn the key, then to see if it goes out. |
8th Apr 2013 4:54pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
how about the steering wheel air bag, i have spoke to story and he is getting back on with the all comms software V8 facelift Range Rover Autobiography 22" wheels.
8th Apr 2013 6:17pm |
On some forums, the suggestion points to the srs ecu. Will Testbook confirm this as I have a local specialist garage that will run a check FOC. |
8th Apr 2013 6:21pm |
