![]() | Home > Technical (L322) > RSW Allcoms won't clear Airbag light FIXED |
^^^^ Thats the way forward. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
The fault has reappeared on allcomms. I'm also getting another fault since taking out the seat which wasn't there previously/ "drive buckle pretensioner".
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
just to confirm,
Yes to all.
it would be handy to know which airbag is faulty and/or what is causing the airbag light to come on ...have you considered removing fuses to see which part is faulty [if this is possible that is].. ... - .- -.
Which fuses control the airbags? |
dunno, you'd have to look on rave .. ... - .- -.
Found the fuse (44) its fine and removing /refitting has made no difference. Just left the battery off for 3/4hr too- still no change.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
ebajema is right, well worth running through all the ECUs and clearing all faults, due to the daisy chain effect! .
Tried them all and cleared the faults I came across. Still the same.
ellismorgan Member Since: 21 Sep 2011 Location: United Kingdom Posts: 9 ![]() ![]() ![]() |
this probably wont help, (re urgent MOT) but I had an airbag fault light on mine (TDV8 2007)
thats the beauty of owning a fullfat. |
Been to the garage today and they stuck the Testbook on and its the ECU thats gone.
Sorted. Bought a used ECU off the bay for £40 and fitted it last night. Airbag light now out! |
