Home > Technical (L322) > engine wont start |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 |
HELP FOLKS about 2 hour ago i went out to the RR and started it up . it started first turn of the key as it always does. i let it run for several minutes as it hasent been running for the week. anyway turned it off and have just gone out again to go out, got in tried to start it but it just turns over continuous with wanting to fire up . i have tried it several times but just turns over. it is a new battery so has plenty of go in it, just wont start.
12th Jan 2013 3:13pm |
thanks for the reply, seems strange that it started perfectly. so could it just fail like that is there any way of checking if its working . i guess a silly question but is it the same pump that is used by the FBH and if not where is the pump situated
12th Jan 2013 3:26pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35425 |
could you roll down off the drive so the range is more on a flat....then try to start it again. ... - .- -.
12th Jan 2013 3:28pm |
hi stan, i had thought of that but im concerned i wouldent be eble to stop ,on in the neighbours gravel drive and and the drive runs about another 40metres with a big ditch at the bottom. not having any air in the system, i dont know if i would be able to stop it. especially as the hand break is not that great
12th Jan 2013 3:34pm |
could be a problem then and maybe doing that might not help...it does sound like fuel starvation though.. ... - .- -.
12th Jan 2013 3:59pm |
hi stan, well i have managed to roll it down onto level ground, but it still wont start. can you advise how i can test if the fuel pump has failed as suggested as a possible problem. i have just had the fbh working so im not out of fuel, and obviously is not the same pump as the one for the engine. is there a picture anywhere showing the pump and its location
12th Jan 2013 4:04pm |
Have a read at this thread |
12th Jan 2013 4:13pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7831 |
12th Jan 2013 4:17pm |
hi mate, thanks for the picture. is the main pump accessed under the spare wheel?, also i have had a look under the bonnet and just to the right on the engine nearer to the front than the rear is what looks like a pump/filter type of thing, which is sitting in a upright position, along with several tubes, a couple of which are clear. these seem to be full of diesel with no air blocks, but there is also a small plastic sort of bowl which is also connected to the other piece via a tube but that is empty is this anything to do with the fuel system is is it something else. perhaps it would be better to post a picture from under the bonnet.
12th Jan 2013 4:29pm |
Looks like the access panels are more under the rear seat, forward of the spare wheel well............
12th Jan 2013 5:09pm |
hi mate, thanks for the pictures. looking at the fuel filter pics, the little plastic bowl,( just to the bottom left of the main filter ), about the size of a cotton reel on your pics looks like it has a little filter in it and has fuel inside it ? is that correct, ie is it another filter for the fuel
12th Jan 2013 5:26pm |
Will check filter in a sec...........though on the other thread, I'm told its the breather for the gearbox............
12th Jan 2013 5:53pm |
It is a breather and nothing to do with fuel
12th Jan 2013 6:04pm |
wow, that high pressure fuel pump looks expensive but i guess at this time i dont really know what is the problem. what doesent make sense to me is that there is fuel in the clear plastic tubes, and would have thought if the pump had packed up, the pipes would have been empty , but perhaps it dont work like that
12th Jan 2013 6:07pm |
