Home > Technical (L322) > engine wont start
Page 3 of 4 <1234>
i gather you're happy then Laughing ... - .- -.
Post #164227 13th Jan 2013 1:17pm
It started...now there's a surprise Shocked
Don't wait too long before changing the pump as it will stop working again and you only get a few hits at it before it packs up completely.
If you look at the link I gave you earlier you will see that the commutator and brushes wear away leaving nothing to make contact and once that happens you're goosed
Post #164247 13th Jan 2013 1:49pm
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
hi stan, ha ha yes i am, but mainly i went into panic mode as im living in the middle of the french countryside; with no dealer for a 50 miles. plus i had just rolled the rangie down the neighbours drive and was now parked right in front of a ditch. ( dutch neighbours, but only holiday home ) fortunately,
so i just had all these horrible senario's going through my mind how on earth i was going to get the car to the garage, or how the garage was going to get it on a trailer etc etc, how much was it going to cost etc etc etc, so yes i am happy at least knowing what it is now.
looking at the location, i think i will do it myself as it seems easy enough Exclamation Exclamation Exclamation Exclamation . ( where have i heard that before ); either that or buy the unit in uk and give it to the dealer to fit, just incase i have bleeding issues.
anyway we will see and i hope not to have to pester you again Embarassed Embarassed Embarassed well not this week anyway Rolling with laughter Rolling with laughter Rolling with laughter
bob
Post #164249 13th Jan 2013 1:51pm
mjdronfield
We are The FF Collective. Resistance is futile !!
Excellent news.
And as to giving you some warning, thats what its just done Laughing
All the best
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #164251 13th Jan 2013 1:56pm
BOBCUSSEN
no worries, i will get one ordered straight away. i dont need to use the rangie as i have other means, so will probably just keep it in My drive until its sorted. ( it was only in next doors as i waiting for electric company to trim our trees that are touching their cables )
thanks again
bob
Post #164252 13th Jan 2013 1:56pm
BOBCUSSEN
hi guys, just waiting to receive the secondary fuel pump from Dan, and i am yet undecided as to whether i will attempt to do it myself or put it into the dealers. would it need to be bled manually or is it simply a case on turning the ignition on for a period before starting? also if i do put it into the dealers, how long a job would you expect it to be Question
any other advice will be greatly received as per usual
bob
Post #166181 20th Jan 2013 9:54pm
No need to bleed, turn the ignition on for a minute, turn it over and Bob's your Auntie Fanny Laughing Laughing
Post #166196 20th Jan 2013 11:43pm
bob
Just put the ignition on once fitted and it will self bleed... Thumbs Up
Post #166199 21st Jan 2013 1:43am
steptoe
BOBCUSSEN wrote:
: , but i would have been happier if i had some sort of warning that it was on its way out.
What you've had is the warning it's on it's way out. Laughing
Post #166244 21st Jan 2013 12:02pm
BOBCUSSEN
THANKS GUYS for the replies Thumbs Up Thumbs Up i think i will try to do it myself if i can get the rangie out of the snow and under cover.
kind regards
bob
Post #166350 21st Jan 2013 5:35pm
BOBCUSSEN
hi again lads, i have just received the pump from dan this afternoon, and am now wondering whether to attempt the changeover myself, or get it to the dealers Question Question
is there anything i should be wary of when taking the old one out? or is it generally easy enough a task to do? and if all goes to plan, how long a job would you expect it to take roughly? Question
Bow down Bow down
bob
Post #168896 30th Jan 2013 7:45pm
Have a read at this thread again Click Thumbs Up Thumbs Up
Just buy a couple of new pipe clips as the old ones will be knackered when you remove them
Post #168917 30th Jan 2013 8:31pm
BOBCUSSEN
thanks for that. sorry i had forgot you had already posted the details. Embarassed Embarassed i will try to get some new clips from somewhere?, Question i did ask dan to send some with the pump, but i think there was a bit of confusion with what i was asking for and i have got the new clips that hold the actual pump in place instead, Cool but not to worry, i will use jubilee clips if i cant find the ones your talking about. Thumbs Up
bob
Post #169019 30th Jan 2013 10:46pm
ebajema
Hey Bob, these type of clips can be gotten from any good automotive parts place that supplies to garages. Find one in your area (not sure if Brezan operates in France already, they do in Holland and Belgium). Make sure you get stainless steel ones !! MY 2010 5.0 SC Galway green and sand interior!!
Post #169039 31st Jan 2013 7:30am
BOBCUSSEN
thanks for that, i will have a look around but if i cant find any, i will ask the local garage. not a dealer but it saves going 70 miles to the next one.
i don't want to risk doing it until i have some new ones. how long do you reckon it would take to do? is it a morning or afternoon's work or an hour ?
best wishes
bob
Post #169207 31st Jan 2013 7:17pm
Page 3 of 4 <1234>
