Home > Technical (L322) > engine wont start |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35433 |
i gather you're happy then ... - .- -.
13th Jan 2013 1:17pm |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 |
hi stan, ha ha yes i am, but mainly i went into panic mode as im living in the middle of the french countryside; with no dealer for a 50 miles. plus i had just rolled the rangie down the neighbours drive and was now parked right in front of a ditch. ( dutch neighbours, but only holiday home ) fortunately,
13th Jan 2013 1:51pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7833 |
We are The FF Collective. Resistance is futile !!
13th Jan 2013 1:56pm |
no worries, i will get one ordered straight away. i dont need to use the rangie as i have other means, so will probably just keep it in My drive until its sorted. ( it was only in next doors as i waiting for electric company to trim our trees that are touching their cables )
hi guys, just waiting to receive the secondary fuel pump from Dan, and i am yet undecided as to whether i will attempt to do it myself or put it into the dealers. would it need to be bled manually or is it simply a case on turning the ignition on for a period before starting? also if i do put it into the dealers, how long a job would you expect it to be
20th Jan 2013 9:54pm |
No need to bleed, turn the ignition on for a minute, turn it over and Bob's your Auntie Fanny |
20th Jan 2013 11:43pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Just put the ignition on once fitted and it will self bleed... |
21st Jan 2013 1:43am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
What you've had is the warning it's on it's way out. |
21st Jan 2013 12:02pm |
THANKS GUYS for the replies i think i will try to do it myself if i can get the rangie out of the snow and under cover.
21st Jan 2013 5:35pm |
hi again lads, i have just received the pump from dan this afternoon, and am now wondering whether to attempt the changeover myself, or get it to the dealers
30th Jan 2013 7:45pm |
Have a read at this thread again Click
30th Jan 2013 8:31pm |
thanks for that. sorry i had forgot you had already posted the details. i will try to get some new clips from somewhere?, i did ask dan to send some with the pump, but i think there was a bit of confusion with what i was asking for and i have got the new clips that hold the actual pump in place instead, but not to worry, i will use jubilee clips if i cant find the ones your talking about.
30th Jan 2013 10:46pm |
Hey Bob, these type of clips can be gotten from any good automotive parts place that supplies to garages. Find one in your area (not sure if Brezan operates in France already, they do in Holland and Belgium). Make sure you get stainless steel ones !! MY 2010 5.0 SC Galway green and sand interior!!
31st Jan 2013 7:30am |
thanks for that, i will have a look around but if i cant find any, i will ask the local garage. not a dealer but it saves going 70 miles to the next one.
31st Jan 2013 7:17pm |
