Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35328 |
android app here,
18th Mar 2014 9:31am |
18th Mar 2014 9:51am |
In stock at Britpart. Call your favorite Britpart dealer and have them ask for part number DA6414 for a 2010-2012 L322 IIDTool (only available in a BT version as the display firmware was not completed to the point where info can be displayed in the cluster - this was only completed for the L405 which has the same hardware. The display will work, but it flickers). RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
18th Mar 2014 11:55am |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 |
Then it means that this latest version enables me to activate the "timed climate" function on central display (not ordered from the factory) on my 2012 tdv8?
18th Mar 2014 2:02pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Hi Guys
18th Mar 2014 6:32pm |
Hi Andrew
18th Mar 2014 7:09pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Do you know what the Bluetooth setting should be in the CCF file for the Bluetooth to work in the UK. I have an updated B/T module and just want to check that I haven't inadvertently change a setting in the Bluetooth when gong through the menus. There is a difference between knowing your sh!t and knowing you're sh!t
19th Mar 2014 2:59pm |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
On a 2004 is there anyway of telling the car to use PAL system like the navcoder?? I know the website site says video soon |
22nd Mar 2014 6:32pm |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 317 |
Hi, can the IID tool code TPMS sensor serial numbers to the TPMS system? I have a set of summer wheels & tyres about to go on, and understand that as they have their own set of TPMS sensors, they will need coding to the car, and vice versa when the winter wheels/tyres go back on in October.
8th Apr 2014 9:34pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Sensors will auto code when fitted and driven - only one that doesnt auto code is spare, and to get around that you just fit it as a road wheel until coded. |
8th Apr 2014 10:48pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
Done a search but can't find anything, and just been on the GAP website to look at the feature list.......
9th Apr 2014 2:37pm |
is that when your switch is on 'side' or 'headlight' ?
9th Apr 2014 2:50pm |
Sorry, yes Stan.
9th Apr 2014 2:54pm |
Remembered to check yesterday, can't get Light On to show on the instrument cluster, let alone the bong. It just puts the "follow me home" lights on and Headlight Delay on the dash when I get bored and turn of the lights after turning the engine off.
23rd Apr 2014 10:05am |
