Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 27 of 49 <123 ... 262728 ... 474849>
Sparkylee
2003 Range Rover Vogue 4.4 V8 Epsom Green
No sorry got held up on the first day of a new job, then school run hopefully tomorrow Thumbs Up
Post #220763 4th Nov 2013 8:11pm
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
My pleasure!
Cheers
Post #220812 4th Nov 2013 10:29pm
Googsy
Anyone know how to put car into tight tolerence mode with the iid tool cant seem to find path thanks. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #221785 9th Nov 2013 1:05am
PatGAPInnov
Site Sponsor
Hi Googsy
Depending on your current firmware version:
V2.17: IIDTool Menu->Service Test->Set Tight or Normal Tolerance
V2.18: IIDTool Menu->Service Test->RLM Suspension->Set Tight or Normal Tolerance
The following is from the user manual of your IIDTool:
-Set tight / normal tolerance
This will set the EAS ECU into tight or normal tolerance mode. In normal tolerance mode, the EAS ECU will adjust a corner when it’s +/- 10 mm or higher than the desired height. For example if the corner is at +9 mm, it will not correct the height. If the corner is at +11 mm, the EAS ECU will make adjustments. In tight tolerance mode, a tolerance of +/- 3 mm is used.
CAUTION
Leaving the EAS ECU permanently in this mode can lead to premature failing of components
Post #221787 9th Nov 2013 1:24am
Googsy
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #221800 9th Nov 2013 8:47am
uphilldowndale
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Hi Steve
Quick question - after much forum trawling have realised why my Park Heat function is not working - and the answer seems to be a GAP IID tool....
I have a 2010MY FF and have had a look at your website - it appears you are still developing the unit for this MY.
How close is this latest version to being released (in case i need to go and buy gloves! )
Thanks
Matt 10MY 3.6TDV8 Vogue SE - Stornoway Grey
Stable Mate: 1961 Series II
Post #223976 19th Nov 2013 7:02pm
Matt, reading one of Steves other posts it seems its going to be about 3 weeks'ish.. ... - .- -.
Post #223978 19th Nov 2013 7:22pm
uphilldowndale
Thanks Stan.
Have just popped to my local indy to borrow their diagnostic. In the words of the mechanic - 'never seen so many fault codes...' Shocked .
Roll on three weeks and I can have a proper look see. 10MY 3.6TDV8 Vogue SE - Stornoway Grey
Post #224074 20th Nov 2013 10:12am
SteveMFr
Site Sponsor
Hi Matt,
Yes, as Stan said roughly 3 weeks or so and they should be available. Only in a bluetooth version as - despite looking very cool in the pic below - the display flickers due to LR not finishing the cluster SW to the point where external messages can be shown w/o probs.
Is your indy used to working on RRs (or D3s, etc)? There are usually quite a number of faults listed but most are either irrelevant due to being a one time issue or due to past probs that have been corrected w/o the fault codes having been erased.
When you've purchased your IIDTool, make a note of any faults you consider important and then clear all. In periodic intervals, check and see which faults come back. These than can be addressed (or ignored :p ). Give us a shout at support at gap-diagnostic dotcom if you have any questions.
Cheers
Steve
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #224257 21st Nov 2013 9:21am
Adjusting Suspension Height
Hi Gap team
I have asked this question els were but I should try here , my car is a 2008 model ; is there a way of lowering access mode but leaving standard and off road as they are ? 2008 MY Supercharged
Post #238429 31st Jan 2014 8:30am
PatGAPInnov
Site Sponsor
Hi Axle
Unfortunately, it is not possible to modify the Access height independently on your vehicle. This can only be done on 2002-2005 RR since these are fitted with a different ECU. The IIDTool allows changing the standard height which is the reference point for all other height modes. For example, lowering the standard height by 10 mm will also lower the offraod and access height by 10 mm. If you need to lower it temporarily, let’s say to wash vehicle or to install luggage on the roof rack, you can use the test valve functions to lower it to the bumpstops. It will only take a few seconds to do it.
Cheers
Post #238508 31st Jan 2014 3:13pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
How is progress for the 2010+ version btw? 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #248549 16th Mar 2014 5:53am
PatGAPInnov
Site Sponsor
The IIDTool BT is already available for 2010-2012 Range Rover. Britpart part number is DA6414.
Post #248866 17th Mar 2014 9:13pm
mmiata
Hungary 2012 Range Rover Vogue TDV8 Buckingham Blue
Then it means that this latest version enables me to activate the "timed climate" function on central display (not ordered from the factory) on my 2012 tdv8? 4.4 TDV8 Vogue Buckingham Blue MY12
from Hungary
Post #248879 17th Mar 2014 10:23pm
g4alan
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Baltic Blue
Ordered a Gap IID tool BT Version 2002-2005 from island4x4 today now I just have to wait for the postman to deliver it and I can start to have some fun.
I can't find any info on the Android app so is it available yet? if it is does it work with a Samsung Galaxy Note 3 or does it only work on an ipad at the moment.
Alan
Post #248931 18th Mar 2014 9:28am
