![]() | Home > General > I'm sure this should'nt happen... |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
Mine traps water between the 2 door seals....
Nogbag Member Since: 19 Mar 2012 Location: North West Posts: 29 ![]() ![]() |
Did'nt realise there are two door seals (but then it is a RR) so maybe it was'nt as bad as first thought. Still likely to catch the unwary out. It reminded me when I test drove a Disco 2 one fine sunny day a few years back - first time I braked, water came pouring out of the headlining above the passenger seat! Still bought it though.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35615 ![]() ![]() |
mine does that after rainfall..i also read that the door gets clogged up at the bottom and needs unblocking .. ... - .- -.
Unfortunatly not a collection, just a rogues gallery of past Rangies I have owned over the last few years....!! |
benjj Member Since: 27 Feb 2012 Location: North Yorkshire Posts: 116 ![]() ![]() ![]() |
Yep, my 2004 TD6 does this too on the rear doors. I've had a damned good look, applied a bit of vaseline here and there but it doesn't seem to be caussing any problems. It has been doing it since I bought the car (nearly 2 years ago) and it has not caused any rust anywhere that I can see.
You can cure the water problem at the rear side doors by placing a piece of 50x50mm timber at the bottom of the door opening and closing the door onto it.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3783 ![]() ![]() |
mine also traps water between the seals on the nsr door, done it since new. |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Ah the old car dealer sagging hinge fix ![]() Adrian VW Amarok 2014 Highline auto |
Thanks for all your replies, good to hear it is'nt unique to the vehicle I looked at but there are too many other question marks against pursuing the purchase of this one so the quest goes on. |
Quite normal but only happens on those where the door shuts allow water in between the seals. Wet shoes only real problem but realignment may help. |
Aurrian Member Since: 29 Aug 2011 Location: Glasgow Posts: 107 ![]() ![]() |
I have this problem on both rear doors since getting the car 2 1/2 years ago, and heard it could be fixed by a dealer. I was going to ask them the first time i visited, but have managed never to visit a main dealer |
Check the lower drains in the doors, all the doors are made to have water enter at the top, its easier to manage the water then to try and make it waterproof (almost an imposibility when you have a drop window) So, check the lower drain holes are clear...
Thanks for that.
Did this last week - and it has worked!!! ![]() Been really p'ing down here most of the weekend - and not a drop of water. Used to get about a pint of water build up in the door seals. Really pleased ![]() Thanks ![]() Thanks |
