Home > General > I'm sure this should'nt happen...
Nogbag
Just been to look at yet another promising potential purchase, an '04 TD6 Vogue. Sounded great on paper (don't they all), reasonably clean inside but when I went to open rear offside door, water came cascading out, more than enough to splash ones shoes (Theresa May would not be pleased). I can only presume rain had seeped in and become trapped by what looked to be a rather hefty seal along the bottom edge of the door. I had already been a bit put off by the lack of any documented history other then the usual stamped book. Also went to look in the boot and straight away saw rust stained and rotting leather pull strap on carpeted spare wheel well cover thingy.
The search goes on....
Post #127151 21st Jun 2012 5:35pm
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Mine traps water between the 2 door seals....
I am sure I read a fix somewhere but damned if I can find it now....
If you have rust spots in the boot area, walk away, the do suffer from leaks on the NSR Quarter area, and it leaks on to the rather delicate Electrical equipment (Sat Nav, Radio, Bluetooth system et al)....
Post #127154 21st Jun 2012 5:51pm
Nogbag
Did'nt realise there are two door seals (but then it is a RR) so maybe it was'nt as bad as first thought. Still likely to catch the unwary out. It reminded me when I test drove a Disco 2 one fine sunny day a few years back - first time I braked, water came pouring out of the headlining above the passenger seat! Still bought it though.
That's a mighty fine collection you've had there Saintv.8
Post #127163 21st Jun 2012 7:28pm
mine does that after rainfall..i also read that the door gets clogged up at the bottom and needs unblocking .. ... - .- -.
Post #127166 21st Jun 2012 7:36pm
Saint.v8
Unfortunatly not a collection, just a rogues gallery of past Rangies I have owned over the last few years....!!
Post #127181 22nd Jun 2012 6:48am
benjj
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Yep, my 2004 TD6 does this too on the rear doors. I've had a damned good look, applied a bit of vaseline here and there but it doesn't seem to be caussing any problems. It has been doing it since I bought the car (nearly 2 years ago) and it has not caused any rust anywhere that I can see.
As for the boot/wetness - I agree with above comments but it is an easy fix. I had it and it was solved with a new OEM LR boot seal which was about £70-80 if I remember correctly. Since then dry as a bone.
Post #127184 22nd Jun 2012 8:00am
You can cure the water problem at the rear side doors by placing a piece of 50x50mm timber at the bottom of the door opening and closing the door onto it.
You then stand on a pair of step ladders or similar and press on the rear top corner of the door with a bouncing motion using the weight of your body.
This has the effect of bending the door frame almost imperceptibly but results in the door closing tighter on the outer door seal. Result, no water between the seals.
Did one of my rear doors a while ago, which was really bad, never had a drop of water since. Very Happy
Door still closes as before.
Post #127187 22nd Jun 2012 8:19am
Vogue
mine also traps water between the seals on the nsr door, done it since new.
Post #127244 22nd Jun 2012 8:13pm
ahebron
New Zealand
You then stand on a pair of step ladders or similar and press on the rear top corner of the door with a bouncing motion using the weight of your body.....
Ah the old car dealer sagging hinge fix Very Happy
Adrian VW Amarok 2014 Highline auto
Post #127259 23rd Jun 2012 5:44am
Nogbag
Thanks for all your replies, good to hear it is'nt unique to the vehicle I looked at but there are too many other question marks against pursuing the purchase of this one so the quest goes on.
Post #127274 23rd Jun 2012 9:31am
Quite normal but only happens on those where the door shuts allow water in between the seals. Wet shoes only real problem but realignment may help.
Post #127288 23rd Jun 2012 11:38am
Aurrian
2005 Range Rover Vogue SE Td6 Java Black
I have this problem on both rear doors since getting the car 2 1/2 years ago, and heard it could be fixed by a dealer. I was going to ask them the first time i visited, but have managed never to visit a main dealer Smile
My indie was talking about changing the door seals so i told him not to bother.
How do you align the doors? Can't find it in RAVE?
Is the door bending trick a good idea?? With window open or closed?
Post #131902 18th Jul 2012 9:41pm
Check the lower drains in the doors, all the doors are made to have water enter at the top, its easier to manage the water then to try and make it waterproof (almost an imposibility when you have a drop window) So, check the lower drain holes are clear...
Craig Thumbs Up
Post #131913 18th Jul 2012 10:35pm
Aurrian
Thanks for that.
Where are they? In the rubber seal?
Post #132089 19th Jul 2012 10:12pm
Aurrian
Did this last week - and it has worked!!! Bow down
Been really p'ing down here most of the weekend - and not a drop of water. Used to get about a pint of water build up in the door seals.
Really pleased Very Happy
Thanks Thumbs Up
Thanks
Post #132504 23rd Jul 2012 1:21pm
