Home > Technical (L322) > cant select gears
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
cant select gears
i had a service yesterday, the wife did a 200 mile round trip today, this evening i went out and when i tried to select reverse there was nothing there, so i tried forward, again nothing. after restarting the car everything was normal.
then when i got home exactly the same thing happened, anyone got any ideas what could be the problem?
i will check fluid levels etc in the morning when it light .
cheers
steve
Post #121377 11th May 2012 8:41pm
Was any work done to the gearbox during the service?
Post #121379 11th May 2012 8:43pm
cleughy
just fluids and filters
Post #121380 11th May 2012 8:46pm
You need to check the levels then.
With the engine running and gearbox at around 43°C put the box into each gear for 3 seconds then into park, next remove the level plug on the side of the box, the fluid should just be dripping out and no more. If no ATF dripping out it will require topping up.
Might be best taking it back to the garage who did the service and watch what they do to check it.
Post #121392 11th May 2012 9:00pm
cleughy
cheers
Post #121394 11th May 2012 9:03pm
RRPhil
47p2 wrote:
....put the box into gear and remove the level plug on the side...
Just to emphasise that you must have ‘Park’ selected when the fluid level is set – clearly it would be risky to be working under the vehicle with the transmission in gear. However, each gear position should be selected in turn & held for 3 seconds before Park is engaged (to ensure that the valve block galleries & clutch lines are filled). The most critical thing is that the engine should be ticking over while the final level is being set and that the sump fluid temperature is between 35 & 45 deg. C
Phil
Post #121448 12th May 2012 10:10am
Scary advice 47p2 Shocked ( I know that is not what you meant Wink)
Wise advice RRPhil Mr. Green .
Post #121454 12th May 2012 10:36am
cleughy
not done it yet but got a "transfer failsafe prog" message coming up now, no problems in sport mode
Post #121465 12th May 2012 11:21am
Blonde moment Joe, I had just finished a 22 hour shift and was about ready for my bed when I typed it
Tanks Phil for clearing up my mess, I've now amended my post Neutral
Post #121493 12th May 2012 4:19pm
Check Gear Linkage on side of box...
Post #121496 12th May 2012 4:40pm
cleughy
it turns out the pump has gone in the gear box, i need full overhaul @£1700 +VAT Big Cry
Post #122082 16th May 2012 10:52am
ouch!!! Shocked ... - .- -.
Post #122083 16th May 2012 10:54am
Odd that it went so soon after an oil & filter change...
Post #122127 16th May 2012 2:02pm
cleughy
i did think it was slightly glitchy whilst driving the previous weekend, but put it down to driving another car all week. The mrs had been driving it more than me lately but she would only notice if it didnt start.
Post #122129 16th May 2012 2:09pm
Ah well at least you have someone to blame Laughing .
Post #122218 16th May 2012 7:32pm
