![]() | Home > Technical (L322) > cant select gears |
Was any work done to the gearbox during the service? |
cleughy Member Since: 08 Mar 2012 Location: West Kirby Posts: 361 ![]() ![]() ![]() |
just fluids and filters |
You need to check the levels then.
cheers |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
Just to emphasise that you must have ‘Park’ selected when the fluid level is set – clearly it would be risky to be working under the vehicle with the transmission in gear. However, each gear position should be selected in turn & held for 3 seconds before Park is engaged (to ensure that the valve block galleries & clutch lines are filled). The most critical thing is that the engine should be ticking over while the final level is being set and that the sump fluid temperature is between 35 & 45 deg. C Phil |
Scary advice 47p2 |
not done it yet but got a "transfer failsafe prog" message coming up now, no problems in sport mode |
Blonde moment Joe, I had just finished a 22 hour shift and was about ready for my bed when I typed it Tanks Phil for clearing up my mess, I've now amended my post ![]() |
Check Gear Linkage on side of box... |
it turns out the pump has gone in the gear box, i need full overhaul @£1700 +VAT |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
ouch!!! |
Odd that it went so soon after an oil & filter change... |
i did think it was slightly glitchy whilst driving the previous weekend, but put it down to driving another car all week. The mrs had been driving it more than me lately but she would only notice if it didnt start. |
Ah well at least you have someone to blame |
