Home > Technical (L322) > cant select gears |
Was any work done to the gearbox during the service? |
11th May 2012 8:43pm |
cleughy Member Since: 08 Mar 2012 Location: West Kirby Posts: 361 |
just fluids and filters |
11th May 2012 8:46pm |
You need to check the levels then.
11th May 2012 9:00pm |
cheers |
11th May 2012 9:03pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
Just to emphasise that you must have ‘Park’ selected when the fluid level is set – clearly it would be risky to be working under the vehicle with the transmission in gear. However, each gear position should be selected in turn & held for 3 seconds before Park is engaged (to ensure that the valve block galleries & clutch lines are filled). The most critical thing is that the engine should be ticking over while the final level is being set and that the sump fluid temperature is between 35 & 45 deg. C Phil |
12th May 2012 10:10am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Scary advice 47p2 ( I know that is not what you meant )
12th May 2012 10:36am |
not done it yet but got a "transfer failsafe prog" message coming up now, no problems in sport mode |
12th May 2012 11:21am |
Blonde moment Joe, I had just finished a 22 hour shift and was about ready for my bed when I typed it Tanks Phil for clearing up my mess, I've now amended my post |
12th May 2012 4:19pm |
Check Gear Linkage on side of box... |
12th May 2012 4:40pm |
it turns out the pump has gone in the gear box, i need full overhaul @£1700 +VAT |
16th May 2012 10:52am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35268 |
ouch!!! ... - .- -.
16th May 2012 10:54am |
Odd that it went so soon after an oil & filter change... |
16th May 2012 2:02pm |
i did think it was slightly glitchy whilst driving the previous weekend, but put it down to driving another car all week. The mrs had been driving it more than me lately but she would only notice if it didnt start. |
16th May 2012 2:09pm |
Ah well at least you have someone to blame .
16th May 2012 7:32pm |
