Home > Technical (L322) > cant select gears
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
It has just been mentioned in the thread that prior ti checking atf fluid, it must be between 35 and 43 degrees. I have also read this in the rave. I do not have the required white man's magic to tell how hot my gearbox oil is prior checking the level. Does anyone one know a good rule of thumb to make sure to oil is hot enough / not too hot, without the afore mentioned technological gizmo's? Cheers gents. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #122418 17th May 2012 3:29pm
RRPhil
Based on a typical fluid temperature rise rate for the 5HP24, if you leave it ticking over for 3 or 4 minutes from ambient you’d be about right
Because the correct fluid temperature is around body temperature (37 deg.C) you could use an old medical thermometer maybe? Forehead thermometer strips usually have a measuring range from 35 to 40 deg.C but I don’t know how well they’d work on a sump pan.
Phil
Post #122458 17th May 2012 6:46pm
woodchopper23
Nice graph, quite interesting Phill. I'll get around to checking my ATF shortly, when I can find somewhere level to park! MY2010 TDV8 Vogue Ipanema Sand
Post #122461 17th May 2012 7:02pm
