Home > Technical (L322) > l322 rain sensor/intermiant
klf400
anyone come across this one
my wipers work constantly on intermitant which is a pain but does have a rain sensor
i am lead to belive when you select intermitant you also select auto so i can only guess the rain sensor thinks its raining
there is no dirt or squashed bugs in front of the sensor
i just want my intermitant to work and no auto sensing i want to be in control of the wipers
any ideas ? 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #99508 28th Dec 2011 8:13am
in that sequence it does set the sensitivity of the wipers..
as for manual intermittent, is that not in the owners manual.. ... - .- -.
Post #99514 28th Dec 2011 9:48am
dan_uk_1984
You can have the "Auto Wipers" disabled by the dealer or by an indy with the right computer. You can then set the variable delay to be 5, 10 or 15 seconds.
However, it would be more to the point if you had the system repaired so that the auto wipers worked properly....
Post #99537 28th Dec 2011 2:01pm
A1GSS
One possibility is in the screen-mounted sensor; do you also have trouble with the automatic lights? The same sensor doubles for both wipers and lights on.
If you pop off the cover surrounding the mirror, the sensor is clipped to the windscreen. It may have fallen off or come unclipped on one side, especially if you've had the screen changed recently. See if you can unclip it and reclip carefully. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #99542 28th Dec 2011 2:13pm
dan_uk_1984
2004 wouldn't have had auto lights - same principle applies though to check the wiring. Especially if it's ever had a replacement screen.
Post #99545 28th Dec 2011 2:21pm
klf400
ok will look at these points and post my findings
i have tried to interrogate the rain sensor with my rsw all comms but cant gain access to it 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #99645 29th Dec 2011 9:34am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
If it's a 2004 without auto lights then chances are it does not have auto wipers either. Mine didn't until I bought the sensors and new LCM (for the lights)
Easy way to check is to look from the outside at the rear view mirror base. You will see the sensor below it if it has them. There is a thread with pics but can't find it right now.
Edit look here (http://www.fullfatrr.com/forum/topic4836.html) - 9th post down by SteveMFR Ash
2016 SDV8 AB
Post #99693 29th Dec 2011 3:53pm
A1GSS
Good shot from comports of a mirror without the sensor. If yours looks like this then there's no sensor:
 Graham
____
Post #99696 29th Dec 2011 4:04pm
dan_uk_1984
Comports has the only Vogue I know of with no rain sensor.
It is/or should have been standard spec for all Vogues from 2002 - although as I said, comports has proven that isn't 100%
You can check whether you have one on Microcat...
Post #99699 29th Dec 2011 4:49pm
A1GSS
Suppose it may have had the screen AND mirror etc replaced at some point in the past. The wiring would be there then, easy enough to check I guess.
Klf400 has a Vogue too; if he's got the same mirror and no sensor then that proves the rule wrong, I suppose. Graham
____
Post #99700 29th Dec 2011 5:00pm
comports
Not any more Dan - thanks to you guys help..!! Thumbs Up Ash
2016 SDV8 AB
Post #99703 29th Dec 2011 5:08pm
dan_uk_1984
agreed... but it would go against all printed LR advertising literature as well as the workshop manuals.
I actually wonder whether comports original owner asked for the car to not have the feature?
Post #99754 29th Dec 2011 10:39pm
klf400
mine has the rain sensor you can see the lens against the screen will unclip and see if its dislodged .
i dont have auto lights , its a Vogue se 2004 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #99758 29th Dec 2011 11:21pm
dan_uk_1984
klf400 wrote:
its a Vogue se 2004
I'd be surprised if it is a Vogue SE being a 2004... the Vogue SE was introduced on the 55 plate. With the occasional 05 sneaking through.
Post #99769 30th Dec 2011 10:34am
johnson1
My mate has an 05 Vogue WITH rain sensor but WITHOUT auto lights. Odd I know...
Post #99806 30th Dec 2011 1:54pm
