![]() | Home > Technical (L322) > Front suspension thump |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
Yup,
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
Would be interested to know if anyone has had this problem after fitting the Dunlop air struts as I don't think they are OEM and the noise on mine only started after I fitted one to my car. |
Originals (and the one I fitted ) are Delphi.
Thanks David, anyone fitted the Dunlop ones with any good results? Like no knocking |
JIMMYM Member Since: 06 May 2010 Location: Saddleworth Posts: 29 ![]() ![]() |
Does the new strut come with top strut bearing that is fitted into the front wing turret - from what I can recall from other cars I've had they're pressed into the top rubber bush. Remember swapping some on my dad's Passat years ago because the bearings had totally disintegrated. Just a thought with number of posts on front suspension knocks - maybe people have already replaced them |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
Have changed the drop links, for £15 and 20min work just do it because mine looked fine but got rid of the "knock over bumps". 2004 black Vogue TD6 |
Just done the drop links & no change at all on mine, still knocking over bumps. The top strut bearing that is fitted into the front wing turret? Didn't know they had one? Just a metal ring on the top of my turret & a thin, what looked like paper or rubber gasket which went back on. I'm getting a ball joint splitter today to change the bottom ball joint arm & see it that works. . . |
I think you'll find that the front strut top mount is a separate item that stays bolted in the wing turret - the paper gasket you refer to is where the strut top plate butts up against the bearing and will be there to stop dirt ingress. There has to be a bearing in top mount to allow strut to swivel to steer and these may be subject to wear and play esp with weight on front end. Someone who's removed a top mount may be able to shed more light or should be shown on Rave parts diagram. |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
On the actual roll bar, there are 2 large rubber mountings that fix it to the subframe, is it possible that they could be worn? Never read anything from anyone about them, but they might be worth checking. Previously..
Does this top bearing stay in place or is it removed with the suspension leg? Would it be possible for it to fall out when the strut was removed or is it bolted to the bulkhead / strut top? I removed and replaced the strut but never noticed anything loos on the top of it ![]() |
Bearing is part of the new strut, it is he bit with the three studs on that bolts through the wing. Can't be left off.
Thats good, thanks David |
Well another day working on the RR and the knock? Still thair |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
Try engine mount |
