![]() | Home > Technical (L322) > Front suspension thump |
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
Good luck David, let us know how it goes . . . . Range Rover 4.4 V8 Vogue |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
Not really much of an update, but do need some input, thoughts, suggestions.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
david, your quote "The knock was there, but much worse, before I changed the strut, so changing the strut did have an effect on the noise." suggests that something that is bolted onto the strut is the culprit...
That's it!
That's the conclusion I keep coming back to David, I know I had no knock at all before changing my strut as if was changed due to a leaking air bag. I changed the strut & the knock was there on the test drive. I have checked my work over again but everything's fine as far as nuts & bolts being tight etc.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Puncture repair |
I have a passenger side functional strut that I took off when replacing mine from '02 spec HSE Diesel. No knocking noise either? Any good?
Joe and Colin,
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
If I remember rightly, the spring rates were changed for the S/C when it was released to give it stiffer handling characteristics.
fisha, I've had the car to 3 different garages including the main dealer & nobody could find the knock. As an ex-mechanic I've also changed almost all the side that's making the noise & the wheel, the suspension strut, trailing arms front and rear, the four rear top & bottom hub bushes, both front drop links, brake pads etc . . . Range Rover 4.4 V8 Vogue |
all i'm saying is that the rattle/bump sound in your vid reminded me of when I had a wheel which was slightly loose due to the bolts loosening off one time. Which made me think that if all the arms, struts, bushes etc have been done ... it still leaves a possibility of the hub itself or wheel bearing having some play, allowing the wheel to move, causeing the sound. V8 or else ... |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
Noise (Clunk) from Front Suspension:
fisha,
