![]() | Home > Technical (L322) > Front suspension thump |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Box of matches? |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
Gaaaah.
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
I go into dunlop were they test and put there struts together they make them in coventry ive seen the testing they do and the workmanship is second to none onto no6 Range Rover Everyone needs a hobby |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
My car started knocking on the front near side recently. It wasnt a heavy thump, more a light knocking over uneven ground, also noticed it if i wiggled my steering wheel from side to side when driving along. I took it to my local garage and they had a look underneath, the near side link rod was the culprit, they also noticed that the lower track rod bush on the same side had a lot of play (I was under the hoist too so could see everything - which is nice as you don't feel ripped off).
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
Just noticed this thread http://www.fullfatrr.com/forum/topic7044.h...sion+knock
I wonder if this could be the problem? Has anyone got a picture or diagram of the parts? I'm pretty sure mine had no hard washers fitted & this could be the problem ![]() |
One hard washer for each drop link, would need to check with Rave, but from memory goes on the joint side at the top, opposite side to the nut.
No I'm still waiting for you to do yours to find out if it stops |
Very quick and cheap to add the washers, nothing much to lose!
I swapped the the old strut top gasket over so that can probably be ruled out. Starting to run out of things to change now (not doing the rack) I can't drive it round knocking and the dealer, myself and a none franchised garage can't find the knock, maybe it's time to get rid |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
Have you done the anti roll bar bushes? |
No not done them yet but I have had it up on a ramp with three different garages & none could see any play in them. I've recorded a film on my phone of the noise which I'll put on YouTube with a link on here if that's allowed. Can't find a way to post it here. Range Rover 4.4 V8 Vogue |
Here's a thought.
That does sound the same as mine, may try removing the drop link. Should eliminate the anti-roll bar bushes to I would think. The phone thing could help if it's gaffer taped to various parts of the suspension. It may destroy the phone but it's probably cheaper than buying a new Range Rover in spare parts |
This is the video I made today of the knock the rattle is just the camera phone mount Range Rover 4.4 V8 Vogue |
