Home > Technical (L322) > Front suspension thump
Page 4 of 8 <12345678>
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I'm not changing the rack, it's a heavy sounding knock and cant be felt through the steering wheel so I don't think it's that.
Post #97866 15th Dec 2011 4:17pm
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
Yup,
Same as mine!
Would love an alternative solution, but pretty much EVERYTHING else connected to the front left corner is new!
David
Post #97869 15th Dec 2011 4:24pm
Glideman
Would be interested to know if anyone has had this problem after fitting the Dunlop air struts as I don't think they are OEM and the noise on mine only started after I fitted one to my car.
Post #97874 15th Dec 2011 5:15pm
rads
Originals (and the one I fitted ) are Delphi.
David
Post #97876 15th Dec 2011 5:24pm
Glideman
Thanks David, anyone fitted the Dunlop ones with any good results? Like no knocking Confused Looks like another thing to add to my try list is a new Delphi strut Big Cry
Post #97878 15th Dec 2011 5:26pm
JIMMYM
Does the new strut come with top strut bearing that is fitted into the front wing turret - from what I can recall from other cars I've had they're pressed into the top rubber bush. Remember swapping some on my dad's Passat years ago because the bearings had totally disintegrated. Just a thought with number of posts on front suspension knocks - maybe people have already replaced them
Post #98135 17th Dec 2011 9:57am
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
letsavit2 wrote:
Yea, change the anti roll bar drop links, £15 from ebay, 4 bolts to change and you don't even need to take the wheels off the car, easy.
Have changed the drop links, for £15 and 20min work just do it because mine looked fine but got rid of the "knock over bumps". 2004 black Vogue TD6
Post #98153 17th Dec 2011 11:40am
Glideman
Just done the drop links & no change at all on mine, still knocking over bumps. The top strut bearing that is fitted into the front wing turret? Didn't know they had one? Just a metal ring on the top of my turret & a thin, what looked like paper or rubber gasket which went back on. I'm getting a ball joint splitter today to change the bottom ball joint arm & see it that works. . .
Post #98163 17th Dec 2011 2:45pm
JIMMYM
I think you'll find that the front strut top mount is a separate item that stays bolted in the wing turret - the paper gasket you refer to is where the strut top plate butts up against the bearing and will be there to stop dirt ingress. There has to be a bearing in top mount to allow strut to swivel to steer and these may be subject to wear and play esp with weight on front end. Someone who's removed a top mount may be able to shed more light or should be shown on Rave parts diagram.
Post #98181 17th Dec 2011 6:14pm
On the actual roll bar, there are 2 large rubber mountings that fix it to the subframe, is it possible that they could be worn? Never read anything from anyone about them, but they might be worth checking. Previously..
Post #98185 17th Dec 2011 6:30pm
Glideman
Does this top bearing stay in place or is it removed with the suspension leg? Would it be possible for it to fall out when the strut was removed or is it bolted to the bulkhead / strut top? I removed and replaced the strut but never noticed anything loos on the top of it Confused
Post #98193 17th Dec 2011 7:45pm
rads
Bearing is part of the new strut, it is he bit with the three studs on that bolts through the wing. Can't be left off.
David
Post #98199 17th Dec 2011 9:29pm
Glideman
Thats good, thanks David Laughing Didn't even know the bearing was their Embarassed
Post #98206 18th Dec 2011 12:05am
Glideman
Well another day working on the RR and the knock? Still thair Big Cry I changed the front suspension arm today at a cost of £75 for an OEM one from the dealers. Also checked all the nuts and bolts again around the passenger side wheel just to make sure I havn't missed any, can't figure out whats wrong with the thing. Never had soo many problems with a car which has only done 100,000 miles. My last car a Subaru Forester had 280,000 miles on it and I never did ANY work on it at all, the RR I have been working on it every weekend since I bought it 4 months ago. Not all trying to find this bloody knock. It's been one problem after another Twisted Evil
Post #98227 18th Dec 2011 4:51pm
oodathort
Try engine mount
Post #98270 19th Dec 2011 9:10am
