![]() | Home > Technical (L322) > Can I plug the car into the mains? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Sounds a bit daft, but rather than running the engine for ages while doing electrical stuff and ibus diagnosis, can I somehow plug the car into the mains so that when in position 1 on the ignition I don't run the battery down? Have googled but not come up with anything viable? .
Yes. just connect up a cheap 12v car charger. I would often do this whilst detailing the interior so I could listen to music for hours without worrying about the battery. |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
If you have towing electrics you can run a charger feed via the trailer feed pin and earth. Graham
Is it really that simple? The FFRR is quite happy having charger connected across the terminals with battery connected? I have a cheap 12v charger, so will give it a go.
Only the same as a Solar or Trickle Charger connected but with more ummmph |
I wouln't connect a "cheap" charger to the car whilst the battery was connected if you value the future reliable operation of your ecu's in future.
Ordinary chargers can cause 'spikes' in the power supply which can damage ECUs if left
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 225 ![]() ![]() ![]() |
I would avoid using an ordinary car charger. The purpose of these chargers are to charge the battery up as soon as possible for convenience – this can often damage the battery if used regularly.
Spare battery and set of jump leads. Connect spare battery to FFRR battery, switch on ignition and do what you have to. When finished disconnect spare battery from FFRR and recharge it separately. |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
With regards to the spikes when connected, I don't see how using a conventional charger is any different to clipping on jump leads. In fact, a charger that only starts when a current is detected is going to do less harm than clipping on some jump leads that can spark when clipping onto the battery.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35610 ![]() ![]() |
if you have a 'regulated' battery charger ,then you shouldn't have any problems.. |
As I understand it the problem is not just the spikes, it's also the ac leakage that can occur due to lower quality rectifiers used in cheaper battery chargers. |
So basically, buy a decent one and avoid the £1 shop/Lidl specials |
The cars electrical system has to deal with voltages ranging from 10V-15V+ due to changing loads, changing charge rates from the alternator and issues caused by different temperatures, as well as massive ampage changes.
