Home > Technical (L322) > Can I plug the car into the mains? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Sounds a bit daft, but rather than running the engine for ages while doing electrical stuff and ibus diagnosis, can I somehow plug the car into the mains so that when in position 1 on the ignition I don't run the battery down? Have googled but not come up with anything viable? .
8th Dec 2011 9:25pm |
Yes. just connect up a cheap 12v car charger. I would often do this whilst detailing the interior so I could listen to music for hours without worrying about the battery. |
8th Dec 2011 9:30pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
If you have towing electrics you can run a charger feed via the trailer feed pin and earth. Graham
8th Dec 2011 9:43pm |
Is it really that simple? The FFRR is quite happy having charger connected across the terminals with battery connected? I have a cheap 12v charger, so will give it a go.
8th Dec 2011 10:21pm |
Only the same as a Solar or Trickle Charger connected but with more ummmph |
8th Dec 2011 10:36pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I wouln't connect a "cheap" charger to the car whilst the battery was connected if you value the future reliable operation of your ecu's in future.
9th Dec 2011 9:13am |
Ordinary chargers can cause 'spikes' in the power supply which can damage ECUs if left
9th Dec 2011 9:25am |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 224 |
I would avoid using an ordinary car charger. The purpose of these chargers are to charge the battery up as soon as possible for convenience – this can often damage the battery if used regularly.
9th Dec 2011 12:40pm |
Spare battery and set of jump leads. Connect spare battery to FFRR battery, switch on ignition and do what you have to. When finished disconnect spare battery from FFRR and recharge it separately. |
9th Dec 2011 1:29pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
With regards to the spikes when connected, I don't see how using a conventional charger is any different to clipping on jump leads. In fact, a charger that only starts when a current is detected is going to do less harm than clipping on some jump leads that can spark when clipping onto the battery.
9th Dec 2011 3:40pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35271 |
if you have a 'regulated' battery charger ,then you shouldn't have any problems.. |
9th Dec 2011 3:47pm |
As I understand it the problem is not just the spikes, it's also the ac leakage that can occur due to lower quality rectifiers used in cheaper battery chargers. |
9th Dec 2011 3:49pm |
So basically, buy a decent one and avoid the £1 shop/Lidl specials 2006 Mercedes CLS
9th Dec 2011 3:54pm |
The cars electrical system has to deal with voltages ranging from 10V-15V+ due to changing loads, changing charge rates from the alternator and issues caused by different temperatures, as well as massive ampage changes.
9th Dec 2011 3:59pm |
