Home > Technical (L322) > Can I plug the car into the mains?
Sounds a bit daft, but rather than running the engine for ages while doing electrical stuff and ibus diagnosis, can I somehow plug the car into the mains so that when in position 1 on the ignition I don't run the battery down? Have googled but not come up with anything viable? .
Post #96790 8th Dec 2011 10:25pm
dan_uk_1984
Yes. just connect up a cheap 12v car charger. I would often do this whilst detailing the interior so I could listen to music for hours without worrying about the battery.
Post #96794 8th Dec 2011 10:30pm
A1GSS
If you have towing electrics you can run a charger feed via the trailer feed pin and earth. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #96796 8th Dec 2011 10:43pm
Is it really that simple? The FFRR is quite happy having charger connected across the terminals with battery connected? I have a cheap 12v charger, so will give it a go.
Thanks guys Thumbs Up .
Post #96802 8th Dec 2011 11:21pm
Only the same as a Solar or Trickle Charger connected but with more ummmph Thumbs Up
Post #96805 8th Dec 2011 11:36pm
Johnte
I was always told you had to disconnect the battery when charging, to avoid damaging the alternator. Is this not true any more, can modern electrics cope with it ?
Post #96815 9th Dec 2011 9:49am
I wouln't connect a "cheap" charger to the car whilst the battery was connected if you value the future reliable operation of your ecu's in future.
Even the handbook recommends you don't do it.
I have a Cteck charger which I use for that purpose and to date no problems.
You could of course just connect another battery to the car, via jump leads, the tow socket or the cigarette socket to increase the capacity of the battery.
Post #96818 9th Dec 2011 10:13am
Ordinary chargers can cause 'spikes' in the power supply which can damage ECUs if left
Not something I would do Joe...
Post #96819 9th Dec 2011 10:25am
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I would avoid using an ordinary car charger. The purpose of these chargers are to charge the battery up as soon as possible for convenience � this can often damage the battery if used regularly.
I would instead opt for a battery conditioner, these are designed to stay on the car for prolonged periods causing no damage and keeping your battery in full health. They (CTEK) can be had for very little money too; and they can come with a Cigarette adaptor so no need to have the bonnet open, the wire just slips through the door shut.
Post #96833 9th Dec 2011 1:40pm
Spare battery and set of jump leads. Connect spare battery to FFRR battery, switch on ignition and do what you have to. When finished disconnect spare battery from FFRR and recharge it separately.
Post #96841 9th Dec 2011 2:29pm
M44K TS
With regards to the spikes when connected, I don't see how using a conventional charger is any different to clipping on jump leads. In fact, a charger that only starts when a current is detected is going to do less harm than clipping on some jump leads that can spark when clipping onto the battery.
Back to the original question though, my Mini is left connected to a battery conditioner that's on a timer plug which comes on for an hour in the morning and an hour at night, the battery has been spot on for 3 years as the car has very little use, but when I'm working on the electrics, the charger is on permanent like Dan says, so I have no worries about a flat battery. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #96855 9th Dec 2011 4:40pm
if you have a 'regulated' battery charger ,then you shouldn't have any problems..
Post #96856 9th Dec 2011 4:47pm
As I understand it the problem is not just the spikes, it's also the ac leakage that can occur due to lower quality rectifiers used in cheaper battery chargers.
Post #96858 9th Dec 2011 4:49pm
M44K TS
So basically, buy a decent one and avoid the �1 shop/Lidl specials Laughing 2006 Mercedes CLS
Post #96860 9th Dec 2011 4:54pm
dan_uk_1984
The cars electrical system has to deal with voltages ranging from 10V-15V+ due to changing loads, changing charge rates from the alternator and issues caused by different temperatures, as well as massive ampage changes.
Coupled with the range of accessories you can plug into the 12v system, ranging from winches to caravans the loads can be quite comprehensive.
So really, plugging in a 6Amp charger will not damage the car. No one mentioned a "fast charger" though, tat would be a different thing I would have thought. But still no more of a kick in the pants than a jump start!
Post #96863 9th Dec 2011 4:59pm
