![]() | Home > General > God bless the FBH !! |
It doesn't matter where i leave mine, though generally i dont think its ever been below 21'c on the dial and i am an 'old skool' FFRR but it shouldn't make any odds as its just heating the interior up as best it can as most of the heat will escape when the door is opened |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I must get mine sorted out. Its only ever blown cold air since I've had it. On the menu, it says "Aux ventilation" or something. Haven't got a remote, so I assume I haven't got the receiver (can't see it in the boot) 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
How do you know if you have a FBH ?
rwilson Member Since: 17 Jan 2011 Location: London Posts: 84 ![]() ![]() ![]() |
Hi i have a tdv8 on an 09 plate, never used fbh before but have heard battery drain horror stories. Is that only applicable on newer my versions? |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 816 ![]() ![]() |
correct
barrieeld Member Since: 07 Dec 2010 Location: Scotland Posts: 260 ![]() |
Hi guys I have FBH with a remote but ive tired pressing in the morning and although I head a fan blowing its not hot in the car and it hasn't defrosted my car? Range Rover SC 35th Anniversary 2006 |
Approx how long did it run for? It will turn off if the battery isn't at full health to avoid running it flat. Also the remote can be set to winter or summer mode I believe. In summer mode it only runs the fans to ventilate the car... |
It ran for about 10 mins just like the fans blowing as you described. How can I change it to winter mode? Range Rover SC 35th Anniversary 2006 |
no such thing as winter or summer mode.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
thats interesting, so in the summer you could set the timer [or if you have a remote system] to expel the hot air so it wont be to hot when you get inside.. |
So what seems to be the problem with mine then? Range Rover SC 35th Anniversary 2006 |
its broken.... |
scarey, that is correct |
MODE To display the current mode, press and hold the [ON] and [OFF] buttons at the same time. If the LED shows RED the appliance is in heating mode If the LED shows GREEN the appliance is in ventilation mode ![]() |
