![]() | Home > Technical (L322) > Front suspension thump |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
Battery tightened.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35472 ![]() ![]() |
as always its a process of elimination...
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
Check for dead cat in the engine under tray? |
you never know joe.. |
Well a metaphorical dead cat...... |
Strut ordered.....
Thanks.
The inner track rod ends are another suspect item worth checking |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
Check your rear hub bushes top and bottom i bet there perished and they do give the inpression that a front shock is not attached to anything onto no6 Range Rover
Mark
That's the ones |
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
Did you ever find out what was causing this knock?? I have exactly the same knock on my front suspension on the passenger side. I've spent a fortune trying to get rid of it. It started when I replaced the front passenger side air strut for a new one. Went for a test drive and first heard the knocking. I've replaced both sides upper and lower hub bushes, this didn't work then the anti roll bar drop links, no luck with that either. I've checked every bolt on the new strut & had the car on a ramp and it's still knocking, it's driving me mad, literally.
Not fixed, still knocking.
