Home > Technical (L322) > Front suspension thump
Page 3 of 8 <12345678>
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
Battery tightened.
Thump still there.
Don't know if I am disappointed or relieved!
David
Post #93535 21st Nov 2011 2:26pm
as always its a process of elimination...
have you a fbh, it so could that be loose.
Post #93537 21st Nov 2011 2:29pm
Check for dead cat in the engine under tray? Wink .
Post #93559 21st Nov 2011 3:56pm
you never know joe.. Laughing
Post #93570 21st Nov 2011 4:28pm
Well a metaphorical dead cat...... Very Happy .
Post #93635 21st Nov 2011 9:58pm
rads
Strut ordered.....
Can't be a dead cat, nothing bouncing.
regards
Schr�dinger
Post #93987 23rd Nov 2011 5:31pm
stevenA
2002 Range Rover Vogue Td6 Zermatt Silver
Check the alignment of the compliance bush - if it is misaligned, then that will give these symptoms.
At normal road height, the flat should be parallel, but if someone has tightened it in the air, then it will not be. Had this on my last FF after they did the diff recall, which involves removing the bushing.
Wrote this up somewhere but have forgotten where Embarassed
Post #94471 25th Nov 2011 6:56pm
rads
Thanks.
Did both the upper and lower arms last week, bushes tightened when back on it's wheels.
New strut going on tomorrow. Fingers crossed!
David
Post #94524 25th Nov 2011 11:49pm
rads
Sad
Good news: Strut was goosed. When we finally (*) got the strut off and layed it on its side, oil from the shock started pouring out of the airbag connection. Shock seals must have gone.
Bad news: Knock still there.
It is MUCH better, whereas before it was so bad I felt the need to explain and apologise to passengers, now I almost have to go looking for a pothole to make it knock, but knock it does. Someone less anal than me could probably convince themselves to ignore it, however...
Had all the undertrays off last night.
No dead cat Thumbs Up
A/R bushes tight, no movement.
All subframe bolts tight.
Steering rack bolts tight.
No movement in gearbox or engine mounts.
I'm starting to suspect (because it's the last bit left connected to the front wheel that isn't new!) the steering rack.
There are a couple of posts here and elsewhere where a front end knock has been attributed to the rack.
Nick67 http://www.landyzone.co.uk/lz/f10/l322-4-4...48412.html
Soupdragon http://www.fullfatrr.com/forum/topic502.ht...ering+rack
However, it's eye-wateringly expensive from LR, and just plain expensive elsewhere, so I would like a bit more confidence before subjecting myself to more open wallet surgery.
Comments?
David
* Strut change pretty straightforward.
Lower bolt through the hub was very tight to remove. Was looking pretty sorry once we had battered it out, but fortunately local Indy (Aylmer Motor Works, Nr Hatfield Herts) came up trumps with one in stock. If I ever do the other side I will make sure I have a spare before starting.
Airline connections to the transfer valve on a 2005 SC a bit different to that show in the RSW videos or Joe's post, only 3 connections, near side is the black connection.
Had a bit of a fright, as had to reconnect the battery to turn the steering wheel after we had depressurised and disconnected the airline and height sensor.
Car started to air up, and it took me a few seconds to get the battery off again.
Was fearing a suspension fault code, but nothing materialised!
David
Post #95471 1st Dec 2011 1:19pm
The inner track rod ends are another suspect item worth checking
Post #95509 1st Dec 2011 2:54pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Check your rear hub bushes top and bottom i bet there perished and they do give the inpression that a front shock is not attached to anything onto no6 Range Rover
Everyone needs a hobby
Post #95522 1st Dec 2011 3:37pm
rads
Mark
Just confirm:
These bushes 5K792A and 3050A in the REAR hub.
Would swear blind knock is from the front, but pretty close to breaking point now and willing to look into all suggestions (except for dead cats).
David
Post #95538 1st Dec 2011 4:12pm
That's the ones Thumbs Up
Post #95583 1st Dec 2011 6:11pm
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Did you ever find out what was causing this knock?? I have exactly the same knock on my front suspension on the passenger side. I've spent a fortune trying to get rid of it. It started when I replaced the front passenger side air strut for a new one. Went for a test drive and first heard the knocking. I've replaced both sides upper and lower hub bushes, this didn't work then the anti roll bar drop links, no luck with that either. I've checked every bolt on the new strut & had the car on a ramp and it's still knocking, it's driving me mad, literally.
Anyone know of anything else to try??
Post #97850 15th Dec 2011 3:26pm
rads
Not fixed, still knocking.
Still suspecting steering rack at this point.
Maybe best if you bite the bullet, get the rack swapped, and come back and let me know how you got on!
David
Post #97858 15th Dec 2011 4:03pm
