Home > Maintenance & Mods (L322) > egr blanking kit for td6
Page 12 of 15 <123 ... 1112 131415>
Promised I'd report back a week on.
Same pattern of driving as the week before, with a couple of additional short runs into town
Distance 254 miles
Ave Speed 36.7 mph
Ave mpg 24.3
So sadly, for me (I only removed the vacuum hose and cleaned out the EGR), no improvement in mpg, and can't say I perceive any improvement in smoothness or performance from the engine. I'll put the vacuum pipe back on and save myself £40 on an EGR blanking kit Wink .
Post #83680 25th Sep 2011 12:24am
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Have had my EGR kit ( Allisport) on for about a week now. Engine seems to run smoother but only a slight improvment in fuel consumption.
Before 11-11.2L / 100 km After 10.8 - 11L / 100 km which for you guys on that side of the pond is about .5 mpg better
Well it was worth a try anyway. But then we are limited to 60mph [ 100 km open road ] otherwise we are classed as a HOON and have our cars taken of us for doing 20mph [ 30 km ] over speed limit. Impounded for 30 days
Gary
Post #84303 28th Sep 2011 3:07am
i've only done town driving in the last 2 weeks and the readout says 22mpg which is 2/3mpg more than before...
when i just blanked off the vacuum pipe the mpg went up by 2/3mpg but soon settled down to normal..when the egr blanking unit was fitted the mpg went up by 3/4mpg but has now settled to a 2/3mpg increase..my conclusion is that this method does work and whether its in my mind or not ,i feel the range does drive more smoothly .. ... - .- -.
Post #84555 29th Sep 2011 9:52am
Well a bit better this week: 25.4 mpg, up from 24.5/24.3, same journeys, but have been a little bit more "assertive" with the driving, actually took it past 3000 rpm twice! Is the car doing some learning on me? not refitted the hose yet. .
Post #84953 1st Oct 2011 11:46pm
33CHINACARS
Well things are a lot better now. Current average is 10.2 l/ 100 km ( ~27.7 mpg) from ~ 11.1 l / 100 km ( ~25.4 mpg) All figures from factory trip computer but then its all relative. So a nice little improvement. Was it worth it YES
Gary
Post #86010 8th Oct 2011 10:29am
Thumbs Up every little helps.. ... - .- -.
Post #86012 8th Oct 2011 10:33am
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Ive just ordered one from DLS
Hopefully I will see an improvement in mpg
Post #91439 10th Nov 2011 2:31pm
When I bought my FFRR last year I had it connected to a computer and was told there was an EGR fault. I removed the EGR and manifold and cleaned it all out, it actually wasn't as bad as I expected. A few weeks ago when I fitted the new idler pulleys I removed the hose to the EGR and it is all still nice and clean, obviously my EGR is jammed shut and not allowing anything to get through Thumbs Up Thumbs Up
Post #91456 10th Nov 2011 3:22pm
Tesh
Fitted mine on Saturday and on the drive to work this morning I saw an improvement to 29.4 mpg on the 21 mile run
Previously it showed 26.3 on the same journey last week
Post #92108 14th Nov 2011 2:02pm
dave.s
any further updates on this as would like know if worthwhile.
going in for service in next couple off weeks and my local indie
will supply and fit for 100.00 at same time.
cheers dave
Post #94576 26th Nov 2011 1:12pm
33CHINACARS
From what I've seen. Worth doing
Gary
Post #94581 26th Nov 2011 1:45pm
dave.s
cheers gary,
just reread the thread and will get it done at same time as service. saves me hitting it with the
hammer and then taking it to the garage as is my usual mechanical expertise.
dave
Post #94593 26th Nov 2011 2:11pm
33CHINACARS
Post #94594 26th Nov 2011 2:18pm
Reattached my vacuum hose today after several weeks of not seeing any real difference in performance, smoothness or mpg (24.5) will see if it goes down now Smile .
Post #94639 26th Nov 2011 7:15pm
Tesh
Definitely worth fitting if you ask me
I'm getting an average 26.6 mpg for the last couple of tanks compared to 22-24 previously
Post #94718 27th Nov 2011 1:19pm
