Home > Technical (L322) > "rear water ingress" |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35328 |
as long as you fit the 'shedder' and maybe use the a/c ,then you will be ok.. ... - .- -.
13th Nov 2011 9:15am |
The water ingress is an easy fix, you need one of these........
13th Nov 2011 9:53am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Or in some cases one of these might be useful
13th Nov 2011 10:00am |
Matt@obsidian Member Since: 29 Oct 2011 Location: Greater Manchester Posts: 70 |
Lol sounds fun in the freelander. Yes I was told it was a seal around the boot but I can't help think they are just finding a job to do without really knowing. Time will tell. Keep us posted Range Rover 4.4 V8 Autobiography Mustang Mach 1 (1971 in grabber green) Honda civic 2.2 diesel VW crafter with ICE |
25th Nov 2011 7:50pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 |
My 2002 TD6 had this problem. I traced the water ingress coming in from the bottom left hand corner of the boot where there are holes in the panel at the rear.(Too dark for photos but will try tomorrow.) I have stuffed a water absorbing rag in the hole for the time being but am looking at putting a lip in place to stop water dripping down into the well. I think it may be the rear wash wipe as it doesn't come out of the wiper onto the screen. |
25th Nov 2011 9:00pm |
Someone else has said the same thing about the wiper. Pictures would be a help to all cheers Range Rover 4.4 V8 Autobiography Mustang Mach 1 (1971 in grabber green) Honda civic 2.2 diesel VW crafter with ICE |
25th Nov 2011 9:14pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
I've just noticed that I've got some of the dreaded water ingress - I have just been out looking and it appears to be coming in from the same place as you refer to - the bottom left hand corner of the boot around the area of the big bolts for the rear bumper.......I can't really see exactly how it's getting in though. Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
25th Nov 2011 9:41pm |
Dried it off and then washed the car - no obvious signs of water when hosing. I then took the car for a drive and came back and checked again - traces of water right at the back of the boot in the double skinned panel and a trickle from there into the tyre well.
26th Nov 2011 12:49pm |
There is a gasket between the bumper and the bodywork where the bolts go through, it might be leaking there |
26th Nov 2011 12:52pm |
Well I reckon its either the bumper brackets or the boot seal.........funny how it has just started leaking...... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
26th Nov 2011 1:56pm |
Here are some pics of where the water is coming in - the bottom left hand corner of the boot.
26th Nov 2011 4:12pm |
Very heful dolphinboy thank you Range Rover 4.4 V8 Autobiography
26th Nov 2011 5:32pm |
kanajobe Member Since: 12 Jun 2011 Location: Bristol Posts: 8 |
Hi
26th Nov 2011 8:06pm |
Dolphinboy, thanks for the pics, that is exactly the same as my issue - coming in through that hole.
27th Nov 2011 4:55pm |
