Home > General > Moving Gear selector becoming Harder
Last couple of days i have noticed that trying to take the gear selector from Park to Reverse is getting a lot harder and stiffer .....
Guessing this is the gearbox linkage on its way out or would it be something else ..... Rolling Eyes Rolling Eyes
Post #87140 13th Oct 2011 8:28am
Yer car's fecked Mick, I'll give you 20 bangers for it if you deliver it here Whistle
Spray the linkage with WD40 or similar..... Thumbs Up
Post #87142 13th Oct 2011 8:32am
have you tried the 'wd40 on the linkage' yet mick.. ... - .- -.
Post #87144 13th Oct 2011 8:36am
After you have got the link pivots and cable free using wd 40 coat them with grease for longer term protection. WD 40 won't protect and lubricate for long.
Post #87146 13th Oct 2011 8:44am
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
Anyone got a "how to" on this, it would be useful for me Thumbs Up
Post #87161 13th Oct 2011 10:13am
Once you have got the Gaiter off , no need to take the gear knob off tho , just spray around the linkage ,i used white lithium grease on mine ….
But i somehow don't think my problem is the linkage , more the button actually on the gear knob ... Thumbs Up
Post #87166 13th Oct 2011 10:25am
i was on about the linkage under the car , worth a try. ... - .- -.
Post #87167 13th Oct 2011 10:27am
Under the car ooooff sorry don't do that stan , that what mechanics are for …. Laughing Laughing Laughing
Post #87169 13th Oct 2011 10:32am
liverpoolphil
Quote:
http://www.youtube.com/watch?v=ndM-2Zpjqe8
Cheers Mick Thumbs Up
Post #87171 13th Oct 2011 10:41am
Why do you need to start it up to move the lever into neutral?
Post #87173 13th Oct 2011 10:44am
Shagging an Italian ... Laughing
Post #87177 13th Oct 2011 10:56am
Under the car, drivers side in-line with front of cubby box.
In between the gearbox sump and the catalytic convertor you will see the link / sliding rod on the side of the gearbox which links the the gear selector knob with the gearbox as in photo.
Simply a case of spraying the two pivots and the sliding rod with wd 40, working the gear selector knob backwards and forwards and when the wd 40 is dry coating the links and rod with general purpose grease.
Should stay lubricated for a while.
Mines just been done so is covered in grease.
Hope this is useful. :)
Post #87192 13th Oct 2011 12:40pm
WIKI WIKI WIKI
http://www.fullfatrr.com/wiki/TDV8_Gearbox...s_of_drive
Stan can you move this out of "Common Problems" into a title of its own please?
Post #87194 13th Oct 2011 1:16pm
ric355
Can't believe how late to the party you were this time. Shocked
Post #87195 13th Oct 2011 1:22pm
Gazellio wrote:
WIKI WIKI WIKI
done and in the wiki gary..
@nicedayforit, thanks for the pic and description... ... - .- -.
Post #87203 13th Oct 2011 1:52pm
