Home > Maintenance & Mods (L322) > Rust Found - Please clean your arches today - Preventable
Page 1 of 5 12345>
swast4
Hi Guys,
I'm a bit gutted Big Cry as I have found some rust/rot on my RR on the botom corner of the rear quarters (bottom corner of the rear door area). there is rust and if I push my my finger in it is slightly soft. I'm gutted because this could have been preventable as I have previously kept the arches clean on other cars but it has passed me by on this occasion.
So don't delay jet off behind those arches or even better still remove the inner liner and clean it properly and protect. You can feel all the soil that is packed in there, which traps moistore and then turns to rust and rot. Unfortunately in past experience when you get rust it is very difficult to get rid of it for good.
I have also got a bit of rust on the rear tailgate on the bottom edge to the left of the number plate trim. Occasionally I get a build up of water that releases when I open my boot especially after washing the car. The drain hole in this area seems to be clear, have you any thoughts ?
Please don't get me wrong my car is a 2002 115K milage it is not mint and would love to have better paintwork which I never seem to have time to do, detail polish etc but I should have caught this, so learn by mistake a capture the problem today as prevention is better than cure.
Adam
Post #77772 27th Aug 2011 12:49am
johnson1
Re: Rust Found - Please clean your arches today - Preventabl
Ouch that's a pain. Anybody with a late 05/55 onwards check now as you'll still be covered by Land Rover's Anti-Corrosion warranty.
Post #77776 27th Aug 2011 6:58am
Reformed
I do my best to keep mine clean. I have only noticed surface rust on mine under the car, nothing major but its there. Reformed
Post #77779 27th Aug 2011 7:33am
I think you'll find they will turn around and just say that you haven't had the yearly body inspection hasn't been carried out and just fob you off Sad
Post #77781 27th Aug 2011 7:42am
L322Pilot
England 2002 Range Rover Vogue 4.4 V8 Buckingham Blue
The rust that you have has I suspect been caused by water accumulation inside the panel and is now through
to the outside. I have the same problem (2002 Vogue) in my rear quater panel. The car is currently in a Land Rover bodyshop and even with discount the replacement panel fitted and finished is costing �2300.
A new tailgate will be much easier to replace.
Post #78556 31st Aug 2011 9:34pm
S11X TT
2003 Range Rover Vogue Td6 Adriatic Blue
Had a look at mine tonight - took the nearside plastic trim and chrome side bar off, not to bad but definately worth the effort to remove as there are clear signs of danger. Rust converter and a good seal to follow.
Will try to add some photos.
Good call. J
PS How do I upload photos? Range Rover TD6 Vogue Adriatic Blue
Post #79945 8th Sep 2011 9:22pm
Jsb
My 07 has the same bubbling starting on rear tailgate, just had authorization from LR for warranty replacement
Post #80170 9th Sep 2011 10:21pm
swast4
Hi S11X TT,
I used photobucket, if you register for free, upload your pics, then when you hover over the pics 4 options come up, use the bottom 4th option click it and it copies the address, then paste it (ctrl V) in your post and hay presto.
Adam
Post #80379 11th Sep 2011 1:24pm
S11X TT
[/img]
Hopefully this works.. thanks Adam
Took the trim off to check on mine.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Range Rover TD6 Vogue Adriatic Blue
Post #80409 11th Sep 2011 3:32pm
S11X TT
This was inside the plastic trim
Post #80410 11th Sep 2011 3:35pm
Was the trim easy to remove? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #80411 11th Sep 2011 3:35pm
S11X TT
Yes, mine has chrome bars which came off first - 2x 13mm bolts and 4x 10mm. The trim was held on by half a dozen plastic screws which came off very easily.. well worth a couple of hours if you have an older ffrr and want to keep it intact.
I also took off the rear wheel arch plastic and had a good look inside there also.
Post #80412 11th Sep 2011 3:43pm
S11X TT
the recess you can see has the plastic screws inside, quite an easy job to remove/ replace.
Gave it a tidy underneath while I was on.
Post #80415 11th Sep 2011 3:49pm
S11X TT
all back on..
Offside to do next time I get a day off (although it seems ok visually as compared to the nearside which seemed borderline).
Post #80416 11th Sep 2011 3:52pm
S11X TT
On the offside the WABCO Air Reservior is stopping the removal of the chrome side bar. Which may stop the removal of the plastic side sill cover. Has anyone had any experience of removing the reservior? (It looks like a small silver coloured silencer).
Thanks
John Range Rover TD6 Vogue Adriatic Blue
Post #80454 11th Sep 2011 7:04pm
Page 1 of 5 12345>
