Home > Maintenance & Mods (L322) > Rust Found - Please clean your arches today - Preventable
Page 5 of 5 <12345
Teaspoonasaurous
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Cheers for that. I've no access to a garage so I may have to drop it to a shop. Would I be better off to bite the bullet now are wait this one out a while?
Post #495826 17th Nov 2018 6:08pm
CS
A stitch in time saves nine. Once it starts you have to keep on at it. Once the rust has been sanded off and the arch repainted it might be worth waxoyling and cleaning/re-doing regularly. Maybe better to try for a decent finish before the winter and road salt etc really get going. Only Range Rovers since 1988
Post #495936 18th Nov 2018 8:24pm
GGDR
Any tips on where to squirt some Waxoyl?
Do you have to remove the inner arch?
Do you have to get it into the sills?
. Cheers, Greg
Post #495938 18th Nov 2018 8:31pm
fisha
I had read on an Jag XK8 thread that the sills were prone to rusting in a similar fashion and a number of people drilled a hole in the sill which allowed them to inject waxoyl on the inside of the sill and then closed it up with a bung. V8 or else ...
Post #495939 18th Nov 2018 8:37pm
Teaspoonasaurous
Marshalls quoted me £600 which seems a bit steep!
Post #495986 19th Nov 2018 1:21pm
JCW
When you remove the lower plastic side sills there are several holes you can use to spray into and reach all the internal areas - I use Dinitrol products which I’d recommend 👍
Post #495989 19th Nov 2018 2:13pm
Page 5 of 5 <12345
