Home > Maintenance & Mods (L322) > Rust Found - Please clean your arches today - Preventable |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 |
Ouch that's a pain. Anybody with a late 05/55 onwards check now as you'll still be covered by Land Rover's Anti-Corrosion warranty. |
27th Aug 2011 5:58am |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
I do my best to keep mine clean. I have only noticed surface rust on mine under the car, nothing major but its there. Reformed |
27th Aug 2011 6:33am |
I think you'll find they will turn around and just say that you haven't had the yearly body inspection hasn't been carried out and just fob you off |
27th Aug 2011 6:42am |
L322Pilot Member Since: 10 Feb 2011 Location: Solihull Posts: 19 |
The rust that you have has I suspect been caused by water accumulation inside the panel and is now through
31st Aug 2011 8:34pm |
S11X TT Member Since: 02 Jul 2011 Location: North East Posts: 20 |
Had a look at mine tonight - took the nearside plastic trim and chrome side bar off, not to bad but definately worth the effort to remove as there are clear signs of danger. Rust converter and a good seal to follow.
8th Sep 2011 8:22pm |
Jsb Member Since: 24 Nov 2010 Location: Southampton Posts: 78 |
My 07 has the same bubbling starting on rear tailgate, just had authorization from LR for warranty replacement |
9th Sep 2011 9:21pm |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 |
Hi S11X TT,
11th Sep 2011 12:24pm |
11th Sep 2011 2:32pm |
11th Sep 2011 2:35pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Was the trim easy to remove? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Yes, mine has chrome bars which came off first - 2x 13mm bolts and 4x 10mm. The trim was held on by half a dozen plastic screws which came off very easily.. well worth a couple of hours if you have an older ffrr and want to keep it intact.
11th Sep 2011 2:43pm |
11th Sep 2011 2:49pm |
11th Sep 2011 2:52pm |
On the offside the WABCO Air Reservior is stopping the removal of the chrome side bar. Which may stop the removal of the plastic side sill cover. Has anyone had any experience of removing the reservior? (It looks like a small silver coloured silencer).
11th Sep 2011 6:04pm |
