Home > Maintenance & Mods (L322) > egr blanking kit for td6
Page 6 of 15 <123 ... 567 ... 131415>
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Ok, getting my EGR blanking kit done next Friday. I'll do my best to get an idea of process as I am not doing the work. I'll also feedback on any diffference to economy and performance of my tractor Very Happy FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #78465 31st Aug 2011 1:34pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Post vacuum pipe blocking update - after a 1400 mile jaunt in the last couple of weeks (largely at 130kph) the fuel computer showed a steady 26.5mpg (was 24.5 previously) on my TD6 - but I still haven't had time to strip out and clean the EGR (one day ...)
Post #78633 1st Sep 2011 11:16am
those extra 2 mpg have saved you some cash already then VV.. Thumbs Up
Post #78693 1st Sep 2011 3:32pm
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
Fitting mine on Saturday, have a new filter and breather as well to help the old girl suck in the O2.
Currently averaging about 23-25mpg __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #78775 1st Sep 2011 8:57pm
what ,where and how much dave, and dont forget to let us know have it performs..
Post #78797 2nd Sep 2011 8:03am
apparently the freelander td4 egr bypass kit is the same as the fullfat td6 so there's a possibility you might find it cheaper.....
Post #78853 2nd Sep 2011 2:02pm
which egr bypass kit would you buy, both £35 delivered..
Post #78865 2nd Sep 2011 2:58pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I bought the top one, but the bottom one looks like it has a place for the vacuum hose to be fitted.
On mine you have to 'bung it'
Post #78868 2nd Sep 2011 3:13pm
GregP
Think I'm going for the allsports one I've seen. FFRR TD6 HSE
Post #78869 2nd Sep 2011 3:25pm
the allisports one looks really good and well made but has a price premium....the bottom one of my pics looks to have a better weld around the base i think..
Post #78870 2nd Sep 2011 3:27pm
Sea Aitch
England 2007 Range Rover Vogue SE TDV8 Zermatt Silver
I bought one from Allisport. It's a really nice looking piece of kit, which is a bit of a shame, because when it's fitted it's hidden. They don't seem to list one now for the TD6, but the picture of the TD4 version on the website looks identical to mine.
Fitting was reasonably simple, but a) you do need an allen key (No.5 IIRC)on a short 3/8 socket extension to deal with the bottom 2 of the 4 fixing studs, b)you need to be confident and firm when removing the metal clamp on the side and c) wear latex gloves and a disposable long sleeved shirt when doing the job. The black crud from the old valve seems to get everywhere.
There seems to be an improvement to fuel economy (early days though), but best of all, if I put the shoe down at night, I no longer lose the headlights behind in a cloud of smoke and the car seems more lively. Smile
Colin
Post #78888 2nd Sep 2011 4:27pm
thats encouraging colin...agree re the bypass kit being hidden when fitted..
Post #78889 2nd Sep 2011 4:32pm
I don't understand the need to buy a kit.
Remove the valve, clean it out, check that it is closed to the exhaust inlet, refit it.
Don't reconnect the vacuum pipe but plug the end of it.
Job done, nil cost. But if you want to spend money on shiny bits....... Very Happy Rolling Eyes
Post #78890 2nd Sep 2011 4:50pm
the difference by leaving the existing valve in place is the air restriction..the bypass kits are straight through so loads of nice cold air gets to the engine..
Post #78891 2nd Sep 2011 4:54pm
Won't make a blind bit of difference imo Smile
You'd actually get a greater benefit taking the inter-cooler out and cleaning the inside and outside throughly. That will increase the air mass flow into the engine.
Post #78892 2nd Sep 2011 4:58pm
