Home > Maintenance & Mods (L322) > egr blanking kit for td6 |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 |
Again very promising
17th Aug 2011 1:06pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35459 |
agreed but remember its only the vacuum pipe i've removed and blocked.. |
17th Aug 2011 2:38pm |
DaveAngel Member Since: 15 Aug 2011 Location: Cowplain, UK Posts: 205 |
Do these plates completly block off the EGR, or just restrict it, i.e. do they have a little hole in? __________________
22nd Aug 2011 8:19pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
The plate blocks the exhaust gas flow completely, no hole. |
23rd Aug 2011 7:52am |
if you do use the blanking kit then you could always sell the egr valve on ebay, thats if you dont want to put your fullfat back as stock.. |
23rd Aug 2011 7:59am |
Awesome - thanks guys will have a go tonight __________________
23rd Aug 2011 3:08pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 |
Ever so slightly cheaper here:
25th Aug 2011 7:13am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
Well, have run with the vacuum pipe disconnected for a few weeks, with no discernable difference in performance / behaviour or mpg. So I have put it back on for now, and await a dry day to take the EGR valve off and have a look. .
25th Aug 2011 8:59am |
i'm wondering what the vacuum pipe actually does ..does it keep the valve open or closed? |
25th Aug 2011 9:04am |
It adjusts the valve according to throttle position and load on the engine. |
25th Aug 2011 9:12am |
so if its disconnected ,will the pressure of the exhaust force open the valve.. |
25th Aug 2011 9:38am |
The egr valve is a spring loaded valve that is normally closed to the exhaust inlet pipe. Application of vacuum opens the valve against the spring pressure.
25th Aug 2011 9:54am |
25th Aug 2011 10:01am |
The pipe needs to be sealed off so that the ECU does not throw up fault codes |
25th Aug 2011 11:39am |
