Home > General > whos fitted an aftermarket satnav |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
ill post pics with a write up for you ...yes you can just plug iphone straight in using the iphone lead that comes with it or via bluetooth,
11th Jul 2011 3:43pm |
well first of all you need to remove the end caps on the dash as below to do this you need to pull the black end covers off and release the airvent to release the air vent you need to put a screw driver into the vent and release the clips inside holding it in place (there will be 4 of these on each vent,
11th Jul 2011 4:21pm |
Lee's Dad Member Since: 05 Jun 2011 Location: In with the POPE Posts: 54 |
11th Jul 2011 5:28pm |
yes porky just do that ... the blue (ant) wire needs to be attached to wire number 4 on the main plug this is as i said the purple wire that goes direct to the canbus box "RANGEISM WILL NOT BE TOLERATED"
11th Jul 2011 6:07pm |
@ leesdad thank you
11th Jul 2011 6:11pm |
993porky Member Since: 25 May 2011 Location: Sunderland Posts: 58 |
Cheers pret for all your help and time great pics Range rover hse
11th Jul 2011 9:35pm |
magicbob Member Since: 03 Jul 2011 Location: Perth Western Australia Posts: 157 |
Thank you Pretlove, for your post, and infi.
11th Jul 2011 10:32pm |
@ magicbob if you ask the seller for the aussie maps im sure he will be fine with that as he sells the units with usa maps unless you ask otherwise "RANGEISM WILL NOT BE TOLERATED"
11th Jul 2011 11:24pm |
BigJ Member Since: 16 Mar 2011 Location: North Yorkshire Posts: 247 |
The GPS antenna will work under the dashboard mate if you get in a thin place, looks a million times better
13th Jul 2011 8:29pm |
thanks big j ...funny you say that i was thinking of moving it today to under the speaker area on the dash "RANGEISM WILL NOT BE TOLERATED"
13th Jul 2011 9:06pm |
for anybody thats intrested in buying one of these units please pm me as ive been asked to be his uk distributer so may be able to do a better price also if you buy direct from him please mention my name Pretlove when ordering as it should help with your discount and speed things up for you "RANGEISM WILL NOT BE TOLERATED"
14th Jul 2011 5:33pm |
Geeezzz, Pretlove, I tried to order that little unit, and the mob doesn't even know australia exists!!! Fair dinkum, I don't know wether their postal dept bloke is a galah, or just has a few loose roos hopping around in his top paddock!!! It's enough do drive a bloke to drink......mmmm...think I'll grab another stubbie!! Magicbob |
7th Aug 2011 8:04am |
dont bother with that unit mate as it doest work with the stereo i brought one and it now just sits next to pc as an orniment "RANGEISM WILL NOT BE TOLERATED"
7th Aug 2011 3:08pm |
Well, I started the install today, pulled the dash off, fitted the new unit in, and...... they have sent me the wrong plug!!.
9th Aug 2011 10:15am |
