Home > Technical (L322) > How to read a wiring diagram
toby1
Hello, a search has proved fruitless but hopefully this is not a re-post.
I think I am working out some of the symbols, colours and letters but I could do with some pointers and if I am on the correct track.
For example, for the engine wiring on a late L322:
1. Looking at the ECM, top left; VBR1 and C0658-3. I assume C0658 is the connector number and 3 is the pin number?
2. Immediately to the left of that it has RW,2.5D,1165. My guess is red white, 2.5mm diameter, 1,165mm length?
3. Immediately to the left of point 2 it has C2552-19 C2553-19 and a symbol of a circle inside a half-circle (reverse C); C2552 and C2553 are connectors, pins 19 and the symbol is two connectors meeting/joining (male/female)?
4. Looking at the green and yellow line in the middle, it has BY. I assume Y is yellow but why is it B?
5. Moving up to the pink and yellow line, what is SJ905? Is it a junction number?
Thanks 2012 Vogue TDV8 in Aintree green over sand
Post #715197 30th Mar 2025 3:32pm
98_Martin
From my experience and knowledge I'd say you're spot on. For your 4th point BY is black with a yellow tracer. The first pages of a wiring diagram often have a colour key and some help with the other points you have mentioned. For your 5th point I'm pretty positive that is just where two wires are spliced into one for example if the pins on a connector cannot carry the required current there might be two pins used instead which then splice into one.
Post #715198 30th Mar 2025 3:45pm
toby1
Yes, I was looking for a legend/glossary but I can't/couldn't find one.
Thanks Martin 2012 Vogue TDV8 in Aintree green over sand
Post #715204 30th Mar 2025 5:34pm
98_Martin
Here's one I found on a L322 wiring diagram for my 5.0, JLR are pretty standard for these things so it should be the same
Post #715205 30th Mar 2025 5:39pm
toby1
Thumbs Up 2012 Vogue TDV8 in Aintree green over sand
Post #715214 30th Mar 2025 7:59pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
The 2006 wiring diagram in the wiki has a chapter on how to read the diagrams, it should cover everything needed.
https://drive.google.com/file/d/1RjjNwCCkD...p=drivesdk
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #715215 30th Mar 2025 8:06pm
toby1
Excellent, thanks. I managed to miss it. Oops. 2012 Vogue TDV8 in Aintree green over sand
Post #715251 31st Mar 2025 10:30am
GraemeS
Australia
SJ stands for solder joint, so solder joint number 905. MY21.5 D350 Vogue SE Carpathian Grey
Post #715258 31st Mar 2025 11:38am
toby1
Thanks Graeme.
I am back home this weekend so I am trying to prepare myself for more ongoing diagnosis for my crank, no-start issue.
I will be probing for voltages around the various sensors and harnesses. 2012 Vogue TDV8 in Aintree green over sand
Post #715269 31st Mar 2025 1:44pm
