Home > Maintenance & Mods (L405) > Gearbox oil change
garyRR
Richie N wrote:
I just contacted RCV for this and they advised against changing the oil unless the gearbox has issues. I am undecided now....
https://www.rcv.co.uk/
Definitely don't use them then!
Generally speaking, the quality of the transmissions and fluid produced by ZF and Mercedes are extremely high, that they could even go 150,000+ miles before requiring a service. Land Rover claim on the L322 that the 8 speed ZF box is "sealed for life" - interesting to see that isn't printed for the L405.
However, transmission servicing is relatively inexpensive and like engine servicing, key to a long life of the transmission. Everyone has their preferences, however every 75k / 10 years whichever comes sooner should be ample on a ZF transmission. Personally, I just do the change at 100,000. It is a messy job but can be done in 2-3 hours at home.
Other automatics such as Fords and DSG boxes need their transmission servicing done like clockwork every 2-3 years/40,000 miles, as dirty and degraded fluid causes clunky changes.
Mannol AG60 is a great fluid to use, but if you keep your eye out online, you can often get the full genuine ZF service kit for sub-£200. 2015 Range Rover Autobiography 4.4 SDV8
Post #687598 9th Mar 2024 9:29am
I did my 322 at about 50k I’ve been a bit lax with the 405 and it’s deffo due for a change. I’ve priced up a ZF pan/filter and oil from AUTODOC, and it’s sitting in my basket having been discounted to £190 for the pan and 8L of ZF fluid.
If I don’t find a new car shortly then I will get it in the garage and give it a go. I seem to remember the L322 was pretty easy to do and I’ve got all the kit this time around. And a diagnostic tool to read the temp.
On the other hand, when I had my 3.6 done LR charged me 1hr to do it if I provided the materials, but that was back when they were hunters…… There is nothing that can't be fixed with a hammer😜😜
Post #707860 30th Dec 2024 1:29pm
pcourtney
I have mine booked in at my local indie in the next couple of weeks, I do it every 2 years ( this time the mileage I have done in those two years is only 25,000 ) , but am still happy to get it done, he told me to buy direct online the genuine ZF Filtran sump from Talexin for only £86 (includes vat and free delivery)
https://talexin.co.uk/product/original-zf-...termarket/
Then they will then double flush with about 10 litres of Mannol AG-60, which seems to be what a lot of indies use, probably because they can get it in bulk drums. I can buy 10L for £70 quid, so if I did do it myself I would be looking at £156 - I am tempted to have a go actually Smile
https://www.mannol.de/products/atf-premium...l-atf-ag60
This has worked for me over the last 6 years ( it will be my third oil change ) , car is coming up for 200,000 miles, I do this mainly because replacement gearboxes are not cheap to replace !
Post #711248 6th Feb 2025 6:48pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
I downloaded the service sheets and every 3 years the transmission fluid must be changed.
Post #711252 6th Feb 2025 7:35pm
pcourtney
which is great for the L405, regular ZF oil service at 3 years, 6 years, 9 years, 12 years
but MY11 L322 is coming up to 200,000 miles, so I'm happy to do it every 2 years for peace of mind, I don't trust manufacturers like JLR ( Jaguar Land Rover ) when they came out with garbage like "sealed for life" - also goes against what ZF in Germany say !
Once the warranty is over JLR simply could not care one iota !
Post #711259 6th Feb 2025 8:00pm
