![]() | Home > Maintenance & Mods (L405) > Gearbox oil change |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3889 ![]() ![]() ![]() |
As I've done over 100k miles I thought I would change the gearbox oil. However, I have been quoted over 500 quid which actually is more expensive than a service, is the oil that expensive or is it a BIG job? Geoff |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
This is what I did. I used Mannol AG60 and paid £72 for 20 litres of it back in 2020. See my post at the bottom of the first page of my thread here: https://www.fullfatrr.com/forum/topic57338.html Dead easy to do on the driveway and gearbox still silky smooth 2 years on and 20k miles later ![]() 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3218 ![]() ![]() ![]() |
Geoff, here's the bill from mine, although I did get it done at the same time as the oil cooler. I was charged 1 hr labour for the gearboxes. On its own could have been more I guess? total cost for gearboxes/transfer box on their own was c. £300 Oil was £154 (7 litres at£22/Ltr). transfer box £30 - all plus Vat obvs!! Here's my bill:
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 298 ![]() ![]() ![]() |
Or, you could give Bodsy a call. I had Ian change my gbox oil and both diffs when I purchased the car. His number is 07770 638023 and he is very reasonably priced.
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 363 ![]() ![]() ![]() |
I just contacted RCV for this and they advised against changing the oil unless the gearbox has issues. I am undecided now....
That really isn't good advice.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
When booking my 6y service (61,000 miles) I asked about gearbox oil change and was told that LR's schedule was 100,000 miles. I might aim to get it done at the next service, so maybe 75,000 miles. Only Range Rovers since 1988 |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
Proper old-school view that is. In the US, where they've bought 80%+ of their vehicles with autoboxes for many decades, generally automatic boxes are understood to require regular fluid/filter changes, and there are numerous places where you can have that done often 'while you wait'. No fluid has an infinite life, and gearbox internals wear, depositing debris in the oil. The filter cleans that up, but a filter doesn't have an infinite life (although, of course, technically its ability to 'filter', although not maintain flow rate, is at its very best at the exact moment preceding it becoming 100% clogged). Automatic transmission manufacturers have long recommended regular maintenance. Only vehicle manufacturers and integrators claim the boxes are 'sealed for life' - but that's just to reduce the maintenance required during warranty period (and hence cost to consumer). After the warranty's expired, they couldn't care less if the box is knackered. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
The LR schedule states 160k or 10 years, whichever comes soonest. The manufacturer of the gearbox (ZF) recommend between 50k and 70k which is much more sensible. Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
From what I have read the best way is to drain the oil , replace the filter and refill with the proper oil ZF Lifeguard I believe and NOT a full flush. overfinch modified |
ZF now approve gearbox 'rinsing' (lost in translation from German, I think) as a service action. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
This prompted me to look at the German version. The ZF FAQ page talks about "Getriebespuelung" which I would translate as flushing rather than rinsing. They make the point that one should flush with clean approved gearbox oil rather than a flushing agent (they expressly say not to use flushing agents).
Indeed - the ZF instructions are very clear that only fluid should be used. The last procedure I read vaguely suggested between 60-100K KM between flushes.
I do our 8sp gearboxes every 30k miles... Never had a failure yet. |
