Home > Technical (L322) > Smoke screen fix by scavange pump modification
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
Has anyone else tried the vacuum pump mod described by Jaguar3? Would be nice to have a confirmation on a different car Smile 2011 Vogue SE 4.4 TDV8
Post #693057 21st May 2024 11:06am
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
I have done it but I can’t comment on whether it would have fixed the smoke issue as I had already done the secondary turbo drain mod in June last year, which did successfully cure my cars bad smoking habit. All I can say is that I did Jaguar3’s mod in November last year and have seen no bad effects from doing it. I just did it because his logic seemed sound and I wanted my scavenger pump to be working more efficiently. My car is a daily driver and I average 300 miles a week. 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #693146 22nd May 2024 6:59pm
Mfcetin
Today I did this modification.
The oil connection was a bit difficult to undo. The push spots for the quick connector are not easy to push, so you need to rotate the pipe a little to be able to pressh two push spots inwards.
It was a bit nerv wrecking to split open the oil side of the pump as I was very gentle not to break the seal inbetween
Another point is the agle of the drilling. If you know the location of the oil feedline, it is easy to estimate the angle.
I will report back after couple of hundred kms Smile
Thank you jaguar3 for this instructions 2011 Vogue SE 4.4 TDV8
Post #701970 11th Oct 2024 12:03pm
pcourtney
@mfcetin - any news on the vacuum and oil scavenge pump shown as item 2 ?
This on my jobs to do in the next few months
1 Oil extraction tube
2 Vacuum and oil scavenge pump
3 Variable geometry turbocharger
4 Engine oil filter (ref)
5 Engine oil cooler
6 Oil feed pipe to turbochargers
7 Cooler and filter housing assembly
8 Oil return pipe
9 Secondary reservoir cover
10 Fixed vane turbocharger
11 Oil return pipe
12 Oil scavenge pipe
Post #710866 2nd Feb 2025 6:42pm
Mfcetin
Dear all,
Sorry for the delay on reporting. I have been quite busy, mainly with our new born Smile
I can definitely say that the smoke has significantly reduced but It is not totally gone.
Before the mod, I would get a big smoke puff after driving city for about a week. It was one large cloud lasting maybe 2-3 seconds
Now after the mod, once in a while i see some smoke if i accelerate hard, but its not that huge of a cloud as before.
To conclude, definitely worth doing specially considering the low effort. Just be gentle when you do the job. A new pump costs like 300 euros in Germany 😬 2011 Vogue SE 4.4 TDV8
Post #710872 2nd Feb 2025 7:43pm
ashtrucker
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Don’t use loose oil from the filler on changing filter if you block the drain hole with the bolt method 2012 Westminster 4.4 tdv8
Post #710920 3rd Feb 2025 12:41pm
pcourtney
I think JayGee has the view that by sealing the hole with an M5 head screw, when he comes to change the oil filter, he is also changing the oil at the same time, so it does not matter if the old oil has nowhere to drain away, by carefully removing the old filter and using rags you can capture most of this old oil as the oil filter comes out.
I also thought about blocking the hole but bought a new rubber bung/valve from America for $12 USD
JayGee wrote:
Pulled the oil release spring and cap just now and the rubber on the cap was very hard so replaced it with an M5 short cap head screw and some PTFE tape to seal it. 5mm is just enough to cut it's way into the alloy housing for a secure fit.
Post #712501 22nd Feb 2025 12:50pm
