![]() | Home > Technical (L322) > Smoke screen fix by scavange pump modification |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
I have done it but I can’t comment on whether it would have fixed the smoke issue as I had already done the secondary turbo drain mod in June last year, which did successfully cure my cars bad smoking habit. All I can say is that I did Jaguar3’s mod in November last year and have seen no bad effects from doing it. I just did it because his logic seemed sound and I wanted my scavenger pump to be working more efficiently. My car is a daily driver and I average 300 miles a week. 2012 Westminster TDV8 4.4 Indus Silver
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 64 ![]() ![]() ![]() |
Today I did this modification.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 841 ![]() ![]() ![]() |
@mfcetin - any news on the vacuum control pump mod please |
Dear all,
ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 37 ![]() ![]() ![]() |
Don’t use loose oil from the filler on changing filter if you block the drain hole with the bolt method 2012 Westminster 4.4 tdv8 |
