![]() | Home > Technical (L322) > 4.4 TDV8 MAP sensor |
Georgi Member Since: 05 May 2024 Location: Sofia Posts: 23 ![]() ![]() ![]() |
Thanks to all the guys that contributed to this thread, I just cleaned the MAP sensor as per the advice here. As a side note - on the screenshots it does not get clear how big is this little
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 218 ![]() ![]() ![]() |
The workshop manual tells you to "clear the powertrain control module (PCM) adaptions" when replacing the MAF or MAP sensors. Is that still necessary when you are just cleaning them? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2642 ![]() ![]() |
Do you have a diagnostic tool that can do it?
I have the IID tool. Just wondered if it's necessary. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 416 ![]() ![]() ![]() |
do we know any reasonablely cheap replacements for the MAP?
